What kinda research are you talking about? I have an HID light in my 04 LR and have not had any issues at all!!! Simple install without any problems, you just have to be sure the ballast will fit into the light bucket!!!
I have the sylvania silverstars and they burn real bright, but have to replace them about once a year. I figure for the brightness I don't mind replacing them. Hell their the easiest thing on the bike to deal with
That sounds pretty ominous. Sounds like you've done some research or had a bad experience. Can you elaborate?
+1, I cant think of any negative issues. If you havent touched the bulb with your bare hands, and even if you didnt when installing a new one, I would wipe it with an alcohol wipe anyway. I would think its due to vibration, check the wire clamp to make sure its holding the base tight and I would go as far as wrapping some electrical tape or something similiar around the headlight housing before you clamp the headlight ring on the bucket.
I have my original stock ones on the 07 with almost 30k on the clock, but someday Il go hid, but I have to buy 2 and a good sets will be expensive.
