New headlight bulb from PIAA
Old Sep 30, 2014 | 06:42 PM
CrazyBones's Avatar
CrazyBones
Default New headlight bulb from PIAA
my headlight bulb went out on a run last weekend and I am looking to replace it, but I was thinking of upgrading to a brighter bulb and found this
PIAA Powersports Xtreme White H4 60/55 Watt Bulb PIAA Powersports Xtreme White H4 60/55 Watt Bulb
#330-752
but cannot find any bulbs to match for the "passing lights". I don't want to have two different light types. any help would be great!
Old Sep 30, 2014 | 09:29 PM
bklynbob's Avatar
bklynbob
www.candlepower.com
They have a lot of bulbs ,you should find what you need.
Old Oct 1, 2014 | 01:32 PM
CrazyBones's Avatar
CrazyBones
ok I will check them out
Old Oct 1, 2014 | 02:18 PM
nikonf8's Avatar
nikonf8
Default Bulbs
The passing lamps are the same from 2006 until now.the 2005 had a different bulb and when they go they have an upgrade to bring you to the newer ones. As far as the head light I went with the truck phase 7 head light and it is one of the most useful mods I have done to date it's bright and you can also see the shoulder of the road worth every penny at 179.00 as far as the passing lamp bulbs it does not matter to me that they do not match the head light I upgraded to the newer bulb housings because I have an 05 deluxe and the I replaced the stock bulbs with 50 what LEDs for a place called so cal motor they are excellent I also run the yellow film on my passing lamps which I beleive is better than buying the amber lamps that some guys buy in auto stores I have heard the blow quite often all in all I spent 240.00 to replace all the bulbs and I could not be happier the difference is unbelievable and worth every penny it's now a pleasure riding at night I can see them pot holes before I hit them highly recommended. The harley head lights are over priced the head light alone is close 450
Old Oct 3, 2014 | 06:02 PM
jimmymiko's Avatar
jimmymiko
Default Match set
Headlight bulb
PIAA 70456 Xtreme White Plus H4 60/55W Bulb PIAA 70456 Xtreme White Plus H4 60/55W Bulb
Passing light bulb
PIAA 70822 881 Xtreme White PLUS 27W=50W Xtra Halogen Bulb PIAA 70822 881 Xtreme White PLUS 27W=50W Xtra Halogen Bulb
These are a match set for color.
I have these and they are super bright way better than stock.
Old Oct 3, 2014 | 06:10 PM
jimmymiko's Avatar
jimmymiko
Forgot to mention, if you go with these bulbs turn them on outside of the lens housing for a few minutes because they give off a vapor that will burn off but if you have them in the housing the will "Fog" up the lens.
Old Oct 3, 2014 | 06:24 PM
rooti's Avatar
rooti
now you tell me
Harley Limited
Jun 17, 2014 01:21 PM
drobison
Jun 24, 2010 08:41 AM
Bushy
Oct 31, 2009 10:06 PM
Stash
Dec 22, 2007 09:15 PM
masterblaster
Mar 12, 2007 02:35 PM
