Progressive 10-1566 lowering kit
Old Jul 18, 2009 | 07:28 AM
skip3406's Avatar
skip3406
Default Progressive 10-1566 lowering kit
Has anyone else bought the Progressive Lowering Kit 10-1566? and did it come with washers?
UPS delivered the kit last night and it didn't come with the 2 washers shown in the picture.
Old Jul 18, 2009 | 07:55 AM
redrubicon2004's Avatar
redrubicon2004
Yep, you will need those. Its been a while since I did mine, so I don't remember exactly where they go, but I think it was in between the springs and the PVC spacer. Bet you could find one at the hardware store.
Old Jul 18, 2009 | 07:57 AM
tweakin's Avatar
tweakin
Originally Posted by redrubicon2004
Yep, you will need those. Its been a while since I did mine, so I don't remember exactly where they go, but they are used.
They go between the spring and the pvc spacer.
Old Jul 18, 2009 | 08:03 AM
redrubicon2004
LOL, I was editing my post when you posted up.
Old Jul 18, 2009 | 08:18 AM
skip3406's Avatar
skip3406
Thanks for the replies.
I can buy them some where if I have to but the point is if they are suposed to be in the kit. I will contact Axiom cycles and see what they will do about it.
I'm in no hurry because I'm waiting until I change the front tire and do it all at once.
Old Jul 18, 2009 | 09:55 AM
NoLongerAmember's Avatar
NoLongerAmember
The washer goes between the spacer and spring. The O.E. set up also has a washer between the spacer and spring so unless the spacer in the kit won't rest on it properly, I do not see any reason you can't use the O.E. one.
CB
Old Jul 18, 2009 | 10:19 AM
skip3406's Avatar
skip3406
CB
Thanks
I know where the washers goes but I don't know if it is the same thickness or diamteter as the O E washer.
Old Jul 18, 2009 | 10:25 AM
Uquackmeup's Avatar
Uquackmeup
If I remember correctly, the instructions tell you to re-use your stock washers.
Old Jul 18, 2009 | 10:35 AM
skip3406's Avatar
skip3406
Thank you, That's the answer I been looking for because I couldn't find that information in the instructions that came with mine
jslum
Dyna Parts
May 8, 2012 10:20 AM
bcmiles
Apr 29, 2012 09:43 AM
IceColdDeluxe
Mar 9, 2011 08:15 PM
jag1886
Dec 23, 2007 11:20 AM
20FXST06
May 23, 2006 01:47 AM
