Best Very Short Windshield?
I completly taped mine up to help protect it. Then used a jig saw to cut it and a small electric sander to smooth it out. Just go slow as you dont wont it to get hot when you are cutting it.
A glass company probally wouldnt charge much to cut it for you if you didnt want to do it yourself.
Harley sells replacement plastic for the shields.
The windshield is thick and looks very well built. The hardware is nice, except that the inside facing brackets are black, not chrome. That bothers me. I installed it with the windshields rack matching the forks angle. I think that looks best on my FXDL.
Riding: At highways speeds, the wind is blocked from my mouth/nose down to my waist and from inside my left shoulder to inside my right shoulder. I am 59. There is a nice vacuum of air behind the screen all the way to my chest. However I can still feel strong air pressure on both shoulders. Is the Fly screen LS effective on chest pressure? Yes. Is it like a bigger windshield? No. But make no mistake it is effective in blocking 75% of the air hitting your chest. I really wish the width was about 2 inches wider. That would match the forks width and look better, plus it would block more of the air hitting my shoulders.
I also installed it as high as possible on the forks in order to block more wind. That looks sort of weird. But I can live with it. If you change the angle to make the windshield more upright, the wind is blocked over my head. But I didnt like the look. Plus I wear a full face helmet, so no need. I like the lower angle matching the forks, so I left it there.
Pros:
- Small size, thus, barely noticeable on the bike.
- Installed easily on my 2008 FXDL.
- Effective in chest wind reduction (my primary goal).
- Low cost.
- Non-handlebar mounting.
- No buffetting at all. Zero.
- Hardware has non chrome pieces that face the inside. Come on. An extra buck would have chromed all the pieces.
- Width is too small. It should match the width of the forks to improve effectiveness and looks.
- Non-Harley OEM.
- Wish it was slightly taller so I could lower it closer to my headlight and still get some air coverage above the handlebars.
- Shoulders still get hit with wind blasts.
If there is something better than a Windvest I would like to se it. Got the standard clear and it all but disappears on the bike. Very effective. I have seen bugs being deflected by the wind being pushed up over the rider many times before.
<a href="http://www.flickr.com/photos/30362847@N06/4505841037/" title="Bike Tag 008 by HeyDoc, on Flickr"><img src="http://farm5.static.flickr.com/4015/4505841037_f0ca622459.jpg" width="500" height="375" alt="Bike Tag 008" /></a>
I then re-cut the shield with a fine jig saw blade and refit it.
<a href="http://www.flickr.com/photos/30362847@N06/4505841041/" title="Bike Tag 010 by HeyDoc, on Flickr"><img src="http://farm5.static.flickr.com/4023/4505841041_bc29707cdf.jpg" width="375" height="500" alt="Bike Tag 010" /></a>
The shield now fits below and behind the light. Great look but still some head buffeting. I trimmed 1.5" off the top edge and polished all my cuts. Getting better but still buffeting above 60mph. I am going to take more off the top, maybe 1 inch at a time and continue testing. Overall "lowering" the shield is working as far as reducing buffeting.
Will try to post pics later - off riding now!
Pros:
- Low cost.
- Non-Harley OEM.
I just completed a 4600 mile trip and there is no way I could have done it without the Flyscreen unless I stayed under 60mph - which isn't going to happen. We cruised at speeds up to 90+ with no pull on the hands.
The only difference between the Gov's screen and mine is that I mounted mine as close to the headlight as I could get it and just behind the ring at the top front. It is also angled just back from vertical. A bit of trial and error was required to get the screen at its best position. It is smoked and looks pretty nice on the bike. That is, if you even notice it.
My son has a Yamaha Warrior (very Harley looking bike). He had the same problem and did the same thing with the same result.
So, if all you are looking for is wind off your chest, this is the cleanest and less obtrusive way to accomplish it.
If you are looking for weather protection, then this is not the solution. If you aren't wearing a FF helmet, then I can't comment on how this would affect you.
Best wishes on your personal solutions.
