sears yellow jack?
Old Aug 14, 2009 | 01:00 PM
dreamer65's Avatar
dreamer65
Default sears yellow jack?
hey guys just got a sears yellow jack, now do u lift your dyna??
I have a fxdc if that helps, any help would be cool
Old Aug 14, 2009 | 01:23 PM
thedonthere's Avatar
thedonthere
with a J&S jack With the yellow one you're going to have to use some sort of spacers due to the oil pan on the bottom and you'll need to strap it to the jack so it doesn't fall off.
Old Aug 14, 2009 | 01:26 PM
dreamer65's Avatar
dreamer65
hahaha
SuperglideKen's Avatar
SuperglideKen
You will need to get a set of Dyna Adapters for your lift. I got mine off of e-bay for $20. I hear you can also get them at your harley dealer. You have to have them because of that oil pan hanging down there below the frame.
WhiteSS's Avatar
WhiteSS
i have a craftsman. i go in from the right side, pull the bike up jack it up a little and make sure it balanced enough. then i get it up two click, strap it to the jack and go to work.
PigInaBlanket's Avatar
PigInaBlanket
Yep I have the Sears yellow jack. I got the HD lifting blocks to use with it and it lifts my 07 Street Bob just fine.
Old Aug 14, 2009 | 01:27 PM
Lorance66's Avatar
Lorance66
Yes, now you lift it
Old Aug 14, 2009 | 01:34 PM
DGDyna's Avatar
DGDyna
Don't want to hijack the thread but does the red jack make it any easier?
Old Aug 14, 2009 | 01:37 PM
PigInaBlanket
If you sit on the bike with your wallet while jacking it up then the yellow jack probably makes it easier since it costs more and makes your wallet a bit lighter.
Old Aug 14, 2009 | 01:43 PM
jknowlton's Avatar
jknowlton
the yellow jack is more durable than the red jack. I have multiple people tell me not to get the red jack, and I have the yellow jack and no problems with it. I went by my friends advice and recommendations, and got it on sale so I have no problems or issues with it. The red one after a few years, they were buying a yellow one. More durable I guess.
