Primary fluid....what does it lube?
Old Aug 15, 2009 | 12:02 PM
El-Infidel's Avatar
El-Infidel
Question Primary fluid....what does it lube?
Seriously, besides the obvious of the clutch.....what all does teh primary fluid lubricate? Im thinkn about removing the primary front and back to run my factory chain drive exposed ( with guards in appropriate places ). I asked in a different thread about the idea.....no responses though. I will be running a scorpion clutch which can be run dry but need to know what else relies on the primaries fluids. Any help?
Old Aug 15, 2009 | 12:06 PM
paul s's Avatar
paul s
The chain is lubed also.
Old Aug 15, 2009 | 12:12 PM
harleyflyboy's Avatar
harleyflyboy
Get a maintenance manual.
Old Aug 15, 2009 | 12:21 PM
SuperFastGlide's Avatar
SuperFastGlide
the inner primary bearing is also lubed by the oil... you cant run an exposed chain unless you want to burn your bearing, the clutch and the chain
Old Aug 15, 2009 | 12:25 PM
ghostrider69's Avatar
ghostrider69
Yeah, there is alot more to running an open primary than just changing out the clutch. Alot more.
Old Aug 15, 2009 | 01:58 PM
skip3406's Avatar
skip3406
All of this plus inner primary bearings.
Old Aug 15, 2009 | 06:12 PM
'09fxdb's Avatar
'09fxdb
So I guess you don't know either.................
Old Aug 15, 2009 | 07:04 PM
jaysonL's Avatar
jaysonL
Old Aug 15, 2009 | 07:22 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
One can get a belt drive set up that is open the the air with fancy cut out cover, runs a dry clutch and a different pulley off the engine, that question is what or how will the IPB be lubed? Is there a special dry clutch IPB, don't know? Start doing some web site searches. The oil also wicks away the heat off the steel plates and clutch plates, lubes the chain, chain teeth on the sprockets and chain adjustment shoe.
Old Aug 15, 2009 | 09:32 PM
SuperFastGlide
yes you use a sealed type bearing on an open primary
