need clutch help
Old Aug 15, 2009 | 08:59 PM
thedonthere's Avatar
thedonthere
Maybe the clutch release plate stripped out. That happened to me and Rich (archergodwin)
Old Aug 15, 2009 | 09:10 PM
archergodwin's Avatar
archergodwin
Yeah, that occured to me as well.... why I asked how much he tighted the jam nut.. .. 'cause I know what happens when you tighten it too much...
Old Aug 15, 2009 | 09:16 PM
bhick21's Avatar
bhick21
It ran fine in ntrl. and when I put it first...just when I started picking up just a little speed (still in first ) it would start clunking pretty loud and then quit as soon as I slowed way down again. I never tried shifting. Didn't mess with any other mechanical parts while installing apes other than the clutch cable install so I figure that's the cause...just don't know how to fix it.
Old Aug 15, 2009 | 09:42 PM
archergodwin
Sorry man... def something's not right.... just can't do much more with eyes on it....
Old Aug 15, 2009 | 10:30 PM
ghostrider69's Avatar
ghostrider69
How much slack do you have in the cable?
Old Mar 26, 2022 | 07:58 PM
Uncleporkchop's Avatar
Uncleporkchop
Default Any resolution?
This is an old thread, but I’m having the same issue. Went from 10” mini apes to 18”. Bought a nice set of lines/cables from magnum shielding and installed everything. Everything went back together on the right side, double and triple checked. Took off the derby cover and adjusted the clutch pack. Still won’t roll in gear with the clever pulled in. The gas tank and fenders just got custom paint so starting it up really isn’t an option at the moment. Fluid is replenished and everything. Just don’t understand what the problem is.
Old Mar 26, 2022 | 08:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You must break the clutch plates free before you can push the bike in gear with the clutch lever pulled in.
Put the transmission into gear, pull the clutch lever and move the bike back and forth to break the clutch plates/discs free.
And even when the clutch plates/discs are broken free, don`t expect the bike to push as easy as if it were in neutral, it`s a wet clutch and there will always be drag between the plates and discs.
Old Mar 27, 2022 | 06:11 AM
Uncleporkchop
Thanks a bunch, I appreciate it.
acg8276
Jan 22, 2015 05:24 PM
BPlo
Aug 3, 2011 05:14 PM
bigdog bigdog
May 29, 2011 01:48 PM
smokin13
May 27, 2009 07:17 AM
gfed87
May 3, 2006 11:35 PM
