Clutch Help
Old May 28, 2011 | 05:52 PM
bigdog bigdog's Avatar
bigdog bigdog
6th Gear
Default Clutch Help
Ok I have installed new clutch cable I went by the instructions to ajust clutch cable and the clutch pack. the bike is still only lift in neutral I pull the clutch in and put it in first gear I hold the clutch in and the wheel will not move. So anyone have any suggestions I have read all the forums about it an have done them to a tee I am out. What amlp I doing wrong please help been on for 2 f###### days
Old May 28, 2011 | 06:09 PM
microwave's Avatar
microwave
try u tube for a vidio on how to adjust a clutch.....
Old May 28, 2011 | 06:40 PM
bigdog bigdog
6th Gear
I did just like the video!
Old May 28, 2011 | 06:48 PM
Stiggy's Avatar
Stiggy
OK you "flipped" the 3 ball ramp on the right side under the clutch actuation cover. ( Never pull the clutch handle when the clutch isn't installed.)
Here's how you fix it. Remove the clutch cover and pull all the slack out of the cable from DOWN there. The lever on the ramp should point straight down or maybe 7 O'clock. Now put the cover back on and then adjust the clutch on the left and then the cable.
If I were to guess, that lever is closer to 4 O'Clock right now, ( already extended so to speak.)
That happens to lots of guys the first time..
Old May 28, 2011 | 06:50 PM
luvtoride's Avatar
luvtoride
I've never done the clutch cable replacement but most of the problems i've read about relate to the connection in the transmission housing. Stiggy beat me to it... good advice
Old May 28, 2011 | 07:43 PM
bigdog bigdog
6th Gear
Thanks I will!
Old May 29, 2011 | 12:42 PM
bigdog bigdog
6th Gear
Ok I did it still I put in first pull the clutch in and still cant push it foward.will I half to run the bike to make it engage
Old May 29, 2011 | 01:37 PM
luvtoride's Avatar
luvtoride
It should roll forward in first with the clutch lever pulled
Old May 29, 2011 | 01:44 PM
bigdog bigdog
6th Gear
Well I dont know what to do
Old May 29, 2011 | 01:48 PM
Stiggy's Avatar
Stiggy
OK. So the 3 ball ramp is in ( lever pointing down,) and you adjusted the clutch on the left side( with the cable still a little loose,) by bottoming out the adjuster screw a couple of times and then backing out the screw 1/2" to 3/4" and securing the lock nut. Then you adjusted the clutch cable to about 3/32" free play.
That sound right?
Dangermouse
May 30, 2013 07:04 AM
2012fxdwg
Apr 9, 2012 08:37 AM
Night train David
Jul 17, 2011 06:26 PM
Wally
Jun 5, 2010 08:00 AM
gfed87
May 3, 2006 11:35 PM
