For the sake of us folk with older scoots, could one of you who owns a Wide Gide and who has a service manual that lists critical fasteners reproduce that list here? I'm sure many people would find it very useful.
I have a 98 Wide Glide, and the manual says to "torque all fasteners, except head bolts, to specifications." That's a lot of bolts! As I understand it, the SM for newer models actually specifies a list of critical fasteners that should be checked.
As an example of what I'm talking about, below is the list of CF's for an '09 Electra Glide Standard, which I found in another thread.
'09 Electra Glide Standard Critical Fasteners
Hand Controls
Switch Housing
Clutch lever bracket handlebar clamp screws
Master cylinder reservoir handlebar clamp screws
Brakes
Brake caliper banjo bolts
Master cylinder banjo bolts
ABS module banjo bolts
Front brake disc screws
Rear brake disc screws
Front master cylinder reservoir cover screws
Rear master cylinder reservoir cover screws
Rear master cylinder to frame screws
Front brake caliper mounting screws
Rear brake caliper to caliper bracket screws
Brake caliper pad pin
Axle nuts
Front
Rear
Front forks
Front axle holder nuts
Pivot shaft
Locknuts
Rear fork bracket bolts
Other Transmission to engine bolts
Rear Frame Bolts
Engine mount bolts
Top stabilizer link to frame
Top stabilizer link to engine mounting bracket bolt
Front engine mount bracket bolts (2)
Front engine mount end cap bolts (3)
Rear frame to main frame (3-each side)
I have a '97 Wide Glide...I'll bring my repair manual in to work and send the info to your email.
Interesting: Mine is a 98 and I don't see a critical fasteners list in my SM, yet your 97 manual has one? That's odd: I wonder if I'm just not seeing it.
No, you are correct. I don't have a "critical fastners" list in my manual (which covers the '97 and '98 WG). The only list I have is for Fastner Torque Values on page 1-9. You have to go through each section to find out what you need to check.
