primary leaking, need ideas!
Old Sep 10, 2009 | 06:06 PM
kk6pg's Avatar
kk6pg
Joe, if you havent done it already, upgrade your chain tensioner to 39929-06a.
The original one in the 06 would tweak and bend, allowing the shoe to ratchet all the way up. Maybe do your IPB while you're in there, and why not do the stator. Did I mention a SE Compensator too?
Since you got it open, might as well.....
Old Sep 10, 2009 | 06:13 PM
lhcstreetbob's Avatar
lhcstreetbob
good luck man im sure you can pull it off you will like the screamin eagle clutch spring... let me know what you think about the sprocket? im sure somebody will let you borrow what ever you need as much as you help everybody out.
Old Sep 10, 2009 | 06:15 PM
redrubicon2004's Avatar
redrubicon2004
Originally Posted by JRK5892
Chad i just sent you a PM... i was going to call you... do you have that sucker? or am i going to have to make one? man... here we go... my awesome welding to make a deep socket... god i hope not... going to be a sad day if you do not have that sucker... anyone on here have one that i can borrow for a weekend?
No, I dont have one. But I could make you one tomorrow insted of doing this----> I have a pretty intense day ahead of me tomorrow
*edit* I just thought about it, I need to make one for my dad's trans pulley. He has a trans output shaft leak he needs to tend to. I could make two! His is 1 7/8"
Old Sep 10, 2009 | 06:25 PM
JRK5892's Avatar
JRK5892
chad that would be AWESOME! thanks man, let me know what i $ ya!
Old Sep 10, 2009 | 06:49 PM
redrubicon2004
Looks like a donor socket is $27 from Sears http://www.sears.com/shc/s/p_10153_1...+1/4%22+socket
Old Sep 10, 2009 | 06:59 PM
JRK5892's Avatar
JRK5892
killer man... let me know and i can run out your way and bring you some $ thanks again bud! I sent you a PM on the chicago site as well... about more power... let me know what you think... give me a shout
Old Sep 10, 2009 | 09:49 PM
redrubicon2004
I picked up the donor socket tonight. Its pretty big!
Can someone who has the correct socket measure how deep it is for me? Thanks!!
Old Sep 10, 2009 | 09:52 PM
0lowrider1's Avatar
0lowrider1
when i had my primary covers off i replaced everything...gaskets,bearing,starter/jackshaft bushings,jackshaft seal,..might want to get a new jackshaft bolt and washer.......i know alot to get but might as well do it now than later
Old Sep 11, 2009 | 07:49 AM
AdrianVall's Avatar
AdrianVall
Make sure you replace the 5 sealing bolts that hold the inner primary, and all gaskets, including that donut shaped gasket. And that big *** nut that you need to get off, is a reverse thread.. so turning left tightens and turning right loosens.
AND BE CAREFUL when you are taking out the 5 OLD primary sealing bolts. They are ****. I broke one trying to get it out. Be very very careful with that crap.
Good luck! I say leave the primary wrinkle. Don't want to much gloss on the bike. It might look out of place.
Old Sep 11, 2009 | 08:30 AM
shimmon's Avatar
shimmon
I think you got enough suggestions to keep you busy... Just wanted to drop ya a line and say thanks for the powdering those bars!!! They look great!
