***H-D instruction sheets database***
Old Sep 30, 2009 | 02:29 PM
  #61
JCK's Avatar
JCK
this should be made a sticky...
Old Sep 30, 2009 | 03:09 PM
  #62
mud's Avatar
mud
it is a stickie... has been since day one...
most folks never look at the stickies...
as you illustrate here........
Old Sep 30, 2009 | 03:13 PM
  #63
8541hog's Avatar
8541hog
Not sure what you see, but it does not show as a sticky when I open the Dyna page. I see 3 Announcements and 2 stickies, and this ain't one of them that I can see.
Old Sep 30, 2009 | 06:46 PM
  #64
tlmitchell's Avatar
tlmitchell
Default Speaking of I-sheets...
After migrating chrome control levers from bike to bike for years the MoCo conspired to force me to buy new ones as the ones on the old sled don't fit the 2010. Having yanked levers off so many bikes I can't begin to count I don't know what possessed me to actually look at the Instruction sheet. I was flabbergasted!
This thing sez in order to install a chrome brake lever to drain the front brake reservoir, remove the banjo, disconnect the lines, etc, etc, etc. WHY? That's ridiculous!
So, as always, I simply loosened the bolts on the master cylinder assembly as well as the switch housings, pulled the pivot pin and the brake lever all but fell out. Stuck the new one in, stuck the pivot pin and snap ring on, retightened the loosened screws and was done.
I gotta wonder how many of the uninitiated are gonna be dousing their bikes with DOT 4 following these absurd instructions? Sheesh......
TL
Old Sep 30, 2009 | 06:58 PM
  #65
8541hog's Avatar
8541hog
Just proves why men don't read instructions..They are written for the lowest common demoninator. It is a legal and safety factor...too many fricken lawyers.
Old Oct 3, 2009 | 03:18 PM
  #66
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
I have added the instruction sheets for the different types (39mm, 41mm, 49mm) DETACHABLE WINDSHIELD AND QUICK-CLAMP DOCKING KITS as used in p/n's 58063-04, 59802-05 and 57340-08.
You'll find them in the ***H-D Instruction sheets database***
___________
FXD2003Rider
Old Oct 5, 2009 | 11:04 AM
  #67
FXD2003Rider
Default new info added 10-05-2009
I have added the instruction sheets for:
68544-10...dyna rear stop/tail/turn signal relocatioon kit (contribution of billjoat)
58006-87B..windshield kit, to be used on 39mm fork "narrow glide" Dyna models (not FXDWG)
58006-87C..windshield kit, to be used on 39mm fork "narrow glide" Dyna models (not FXDWG)
___________
FXD2003Rider
Old Oct 11, 2009 | 09:58 AM
  #68
FXD2003Rider
62974-09...lcd oil temperature/level dipstick
___________
FXD2003Rider
Old Oct 11, 2009 | 02:32 PM
  #69
FXD2003Rider
Based upon the
2007-09-stock-lowrider-handlebars-and-risers-part-numbers thread
I have added the info on the deluxe pullback riser and clamp kit (p/n 56290-05)
to the ***H-D instruction sheets database***
Old Oct 12, 2009 | 08:50 AM
  #70
FXD2003Rider
Based upon a question in the How Do I take this Headlight Apart? thread I have added the instruction sheets for:
69851-06....4-1/2" bullet headlamp kit
68593-06....5-3/4" bullet headlamp kit
___________
FXD2003Rider
