front end clunk
Old Sep 25, 2009 | 09:40 AM
iamrfixit's Avatar
iamrfixit
Angry front end clunk
Noticed a slight clunk in the front end on my 08 WG over the last couple weeks. Only really when hitting a bump, no wobble or other problems really just a little noise. Yesterday it made even more noise so I decided to check it out and adjust the fall away.
Had to remove the bars and lay them back on the tank to get a socket on the steering head nut, I removed the chrome cap and grabbed the steering head nut with my fingers and it moved! It was completely loose, not even finger tight.
It has almost 5K on it now, bought this spring with 1300 miles on it. The steering head nut is torqued to 80 ft lbs, I can't believe it worked loose so that means some idiot left it loose. I took it for a 1K service after I bought it to be certain it was done. Makes you wonder what you are paying the "pros" for!
I guess I will do my own service, planned to anyway but didn't have a service manual at the time.
Old Sep 25, 2009 | 10:10 AM
jmpancoast's Avatar
jmpancoast
Just to validate your point.....
I have a friend who had the clunk, took it to the dealer to have the work (per the service bulletin) done. Got it home, he still had the clunk. I went to check it for him, removed the stem cover, and the nut on his was also finger tight.
+1 one on self servicing these things.
Old Sep 25, 2009 | 11:18 AM
RCB's Avatar
RCB
The 1k service is an overpriced/glorified oil change. The best investment you can make for your bike is purchasing a service manual.
Old Sep 25, 2009 | 11:44 AM
Black Bart's Avatar
Black Bart
+1 on that!
Bart
Old Sep 25, 2009 | 04:43 PM
iamrfixit's Avatar
iamrfixit
Yep,
I went in to pick up oil and filter and the parts guy went into this song and dance about how important it is to have the "pros" do the service since the spokes need adjusted and all the important fasteners that need to be checked over and how the warranty might be affected. I didn't have a manual and they were out of stock, but that is the first accessory I bought.
This being my first HD I had a little learning curve. I worked on all my other bikes and have wrenched on about everything from semi's to bicycles over the last 30 years.
Lucky for me they performed two services for me that day.... My first and also my last.
Old Sep 25, 2009 | 04:47 PM
RCB's Avatar
RCB
Originally Posted by iamrfixit
Yep,
Just keep your receipts and a log book of the services/work you do to the bike.
getblended
Feb 15, 2015 11:42 AM
framer
Feb 4, 2011 04:23 PM
Former dirt rider
Sep 24, 2009 04:04 PM
OneBlackFly
Jul 27, 2007 08:17 AM
slackwolf
Jul 4, 2007 10:38 PM
