Am I getting myself in too deep with front end?
With the weather getting colder up hear in the north, I've been thinking more and more about my plans for winter mods for my 08 street bob. For a while, I've been planning on getting the sliders, trees, sigs, shocks, forwards powder coated flat black. I plan on taking everything apart and dropping it off.
I'm not an expert wrench, however I've done the ac/pipes, apes, true track and a bunch of other stuff. I've read through the manual on the procedures a few times, but I know things get a little easier once everything is in front of you rather than in a book. My question is, am I getting myself in too deep?
My biggest concerns are the front sliders and trees. Always have the ol' 'leave well enough alone' saying in the back of my head. Any input/tips would be appreciated!
The good thing is there are guys on this forum that will lend a hand and advice.
If you have a look your after - you'll never be satisfied until its done. You'll end up saying - I shoulda powdered the sliders when I changed the trees or something like that.
Get a roomy work space with plenty of light and space to lay things out this way your not tripping over wheels and cables.
I'm sure you have the manual already - so read threw the "removal" and "installation" sections - and take note of the tools you may need - like a inch and half socket!
And if you don't already have one - get a good jack - I'll plug J&S Jacks because it works great not because I work for them. Other guys are using the sears red, yellow and harbor freight units and are having no problems - so that's your choice. I went with J&S.
I'm sure folks will chime in and will be there to help along the way.
Go for it.
George
You have the manual, take your time and just lay it out as it comes a part. I always tell people that, if you lay it out properly it will go together like it came a part!
You'll REALLY be proud of yourself once it's done too.
things you need...
-a good lift...J/s makes a great dyna lift
-The service manual- has torx specs and some usefull info
-the parts manual- that is worth it weight in gold in my eyes...it has the part breakdown of the whole bike and was very helpful to me on my front end work
I would recommend taking pictures and mybe even doing it with a buddy. And you should take your time...dont rush
Only snag I had was setting the front fork seals...i brought them to dealer to set and they scratched one of my lowers and I had to send it out to be repowdered...set me back another week..
When you take stuff off to be powdered...look to see if you want the head of the bolts powdered also...i think so many people dont powder the bolts they stick out like sore thumbs...the heads of bolts/nuts/washers can be powdered.
Jay
Can this be done with a sears lift and a couple scissor lifts to support the rear? Also, the setting of the seals is something I was concerned about, and I wanted to avoid my stealer. Is it really that difficult to do?
To set the seal you need a 49mm seal tool...the tool is over $100...and the dealer only charged me $25 to set both seals...i went around my town to a few local bike shops and they did not have a 49mm seal tool...i sucked it up and paid the $25...and made them pay to repowderder the lower they scratched....
Jay
I screwed some long eyebolts into the sole plates in my garage and then ran ratchet type straps to the bike so there was no way it could fall off the jack.
