Free windshield - no bracket
Old Oct 5, 2009 | 08:35 AM
DGDyna's Avatar
DGDyna
Question Free windshield - no bracket
Can someone tell me where to get a bracket for this windshield?
I have an '09 SG (49mm fork tubes) with a Sportster style speedo and tach on the front of the bars. I need the windshield to clear the gauges.
Old Oct 5, 2009 | 09:45 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
I guess this is the windshield that comes from the "windshield kit, p/n 58006-87B or 58006-87C to be used on 39mm fork "narrow glide" Dyna models (not FXDWG)
A simular type of windshield was mounted to my 2003 FXD when I bought it 4 years ago.
If you need additional images, just let me know and I'll post some.
You'll find more details on the p/n's in the ***H-D instruction sheets database***
IMO you have to do some remodeling in order to get it mounted to your '09 SG with 49 mm forks.
You'll find some info on the use of 49mm clamps in this post as a part of the has anyone used this fairing before?? thread.
___________
FXD2003Rider
Old Oct 5, 2009 | 02:59 PM
DGDyna's Avatar
DGDyna
Default Bump
I hate bumping a thread but someone must have some experience with this type of windshield mount. Is it worth keeping or should I just throw it in the trash?
Old Oct 5, 2009 | 06:10 PM
SC-Longhair's Avatar
SC-Longhair
The first thing I'd do is find out the p/n, if it's an HD windshield. Maybe finding out what it came off of might be easier way to the p/n...then on to what you need to mount it.
Old Oct 5, 2009 | 06:37 PM
HDDyna2006's Avatar
HDDyna2006
I don't know man, but it looks all beat up and scratched.
Old Oct 6, 2009 | 12:03 PM
G-Spot's Avatar
G-Spot
6th Gear
I'd pitch it. Looks too scratched. Similar to one I've seen before that bolts directly to you fork so there may not be any type of 'adapter' that's needed.
Some bikes (like my 02 WG) have a bolt at the top of the fork for this type of windshield but the windshield also usually has another part that connects to your bars for stability.
Old Oct 6, 2009 | 12:24 PM
JRK5892's Avatar
JRK5892
i would think that you could use the same hardware kit that all the 49 mm tubes use... do not see any reason why not. that looks like an american shield windshield
Old Oct 6, 2009 | 12:48 PM
FXD2003Rider
Originally Posted by G-Spot
...but the windshield also usually has another part that connects to your bars for stability...
Have you checked the instruction sheets on 58006-87B or 58006-87C in the instruction sheets database?
IMO there's not such a part in the mounting diagram (see attachement).
Originally Posted by SC-Longhair
...The first thing I'd do is find out the p/n, if it's an HD windshield...
The p/n for the windshield is 58061-96 (see diagram in att. and instruction sheets database for "windshield kit compact replacement... 57716-01")
___________
FXD2003Rider
Old Oct 6, 2009 | 01:41 PM
FXD2003Rider
Joe,
I agree with you on the 49mm clamps.
There could be a slight problem in the width of the hole pattern were the adjustable brackets (see att. 1 pos. 15 & 16) hold the windshield in relation to the width of the 49 mm forks.
The brackets on the shield I had on my 2003 Dyna are spaced 11" (see att. 2)
Question now is: what is the space between the (outer)side of the 49mm clamps when mounted to the 49mm forks (see att.3). If this is 11" or less, this shield would fit. If it is more some remodeling has to be done.
___________
FXD2003Rider
Attached Thumbnails Free windshield - no bracket-hole-pattern.jpg   Free windshield - no bracket-dyna-compact-shield.jpg   Free windshield - no bracket-49-mm-mounting-clamp-configuration.jpg
Old Oct 6, 2009 | 01:46 PM
DGDyna's Avatar
DGDyna
Looks to me like it's not worth the effort. Expecially considering the condition of the windshield itself.
