wide tire on a Super Glide 2003
Old Oct 7, 2009 | 07:47 AM
de79's Avatar
de79
Default wide tire on a Super Glide 2003
Hi guys,
I recently bought a 2003 Super Glide. Now I want to install a wide tire on it (180). What are the possibilities?
If you have cool links to customized Dyna sites you can also post them.
Thx,
De (from Belgium)
Old Oct 7, 2009 | 07:59 AM
bberck's Avatar
bberck
I dont think it will fit under the fender, as it is pretty tight under the newer wider fenders.
Also pretty sure your rear wheel is narrower than the newer Dynas, so it wouldnt be a safe mount.
Old Oct 7, 2009 | 08:18 AM
de79's Avatar
de79
Hi bberck,
would it be possible with another wheel and fender (without changing the other parts)?
btw Nice bike !!
Old Oct 7, 2009 | 08:28 AM
doorsidedown's Avatar
doorsidedown
what about a 160? you can probably fit that under your fender as it sits.
Old Oct 7, 2009 | 08:34 AM
de79's Avatar
de79
on mine is alreay (standard) a 150 (Dunlop 150/80 B 16). So I think a 160 will fit but I would rather like a 180.
Are dyna models in the USA standard equiped with a 130 or a 150 tire?
greetzz
Old Oct 7, 2009 | 09:16 AM
Maimas's Avatar
Maimas
You would have to install a wide tire kit... And change the rear fender.
Old Oct 7, 2009 | 09:34 AM
de79's Avatar
de79
do you have an idee what is included in a wide tire kit? How much does it cost in the US?
Old Oct 7, 2009 | 11:29 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
De79,
First of all welcome to the forum from the Netherlands. This is the place to be: lots of interesting info and helpful people who share the same passion...their Dyna!!
When I look at my 2003FXD I don''t think you can mount a 180 tire to your 2003 Dyna without changing the swingarm and fender (7 1/2 inch to 8 1/2 inch). You will have to set off the inner primary and the front pully too. Dyna models frames (included swing arm) changed in 2006; these frame accept 180mm tyre.
To give you an idea what's in the wide tire kits check these links
http://sales.artinmotionllc.com/200w...ngarmdyna.aspx
http://stores.shop.ebay.com/Classic-...Tire-Kits.html
___________
FXD2003Rider
Old Oct 7, 2009 | 11:55 AM
de79's Avatar
de79
thank you 'neighbor' for the info. This is indeed a really interesting forum. I had a long search for a decent HD forum and I'm glad I found one!
Old Oct 7, 2009 | 12:37 PM
FXD2003Rider
If you need some help or info......just let me know by email or PM (personal mail)
You should start checking out the " sticky" threads "HOW TO" and "SEARCH TOPICS"
Have fun!!
___________
FXD2003Rider
chrison600
Sep 27, 2024 07:39 PM
CWS
Sep 3, 2015 06:48 AM
Twincruiser
Oct 2, 2014 08:40 AM
gordo68
Aug 28, 2010 11:34 PM
Kiraly
Jan 13, 2008 11:35 AM
