***dyna models metric sizes database***
Old Nov 4, 2009 | 12:33 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Default info added to database
Originally Posted by mud
Rene, I don't think you have this one yet...........
clutch spring / pressure plate bolt
6 x 1" x 16
part # 2980
use 10mm wrench/socket
Mud,
Your contribution to the database is much appreciated!
I have checked my 2003 models parts catalog for this p/n and found out it's the same as used on the 2006 models.
Could you be so kind to add a link to this database in the *Search Topics * How To * Hints*?!
Thanks again,
René
Old Nov 4, 2009 | 02:37 PM
FXD2003Rider
Default new info found and added
After checking the hardware listing in my 2003 Dyna models parts catalog, I've found some more metric size bolts and nuts:
horn section:(see attachment #1)
horn/horn bracket nut M6, p/n 7495 .... 10mm 6-point hex wrench/socket
starter motor section:(see attachment #2)
NUT, flange M8, p/n 3403 .... 13mm 6-point hex wrench/socket
BOLT, starter M5, p/n 928 ... 8mm 6-point hex wrench/socket
SCREW w/ O-Ring M4, p/n 929A ... 7mm 6-point hex wrench/socket
___________
FXD2003Rider
Attached Thumbnails ***dyna models metric sizes database***-horn.jpg   ***dyna models metric sizes database***-starter-motor-metric-parts.jpg
Old Nov 4, 2009 | 06:06 PM
mud's Avatar
mud
Originally Posted by FXD2003Rider
Mud,
Thanks again,
René
It is now added René.
also, as a companion to your 4042 bolt,
we have pn 7062
metric lockwasher M8.4 x 13 x 1.2
Old Nov 6, 2009 | 02:08 PM
FXD2003Rider
Default new info added
also, as a companion to your 4042 bolt, we have pn 7062 metric lockwasher M8.4 x 13 x 1.2
Thanks for the info, mud! It has been added to the database (see attachment).
FXD2003Rider
Attached Thumbnails ***dyna models metric sizes database***-axle-cap-washer-and-bolt.jpg
Old Nov 7, 2009 | 10:04 PM
motolocopat's Avatar
motolocopat
Considering that by the time you buy 3-4 sockets or wrenchs you could have bought a full set it looks like it would be best just to get a full set of metric tools.
Heck you can buy quite a nice set of craftsman sockets/wrenchs/allens for about $125
Old Apr 20, 2010 | 01:06 PM
FXD2003Rider
Default new addition
This morning when I fired up my FXD2003 to go to work, I noticed the choke/enricher knop didn't stay out and slid back, so I decided to adjust it after I came home this evening.
Doing this, I tried a 5/8 wrench which seemed to be to small so I took a 11/16 which was just a little overzised.
Trying a 17mm wrench I discovered this nut is a hex nut 17 mm, so here's a new addition to the metric sizes database.
Wondering what size nut is used on the other Dyna models/years??
If you check and let me know I'll add your info to the database as well!
Old Apr 20, 2010 | 03:38 PM
Ratbob's Avatar
Ratbob
Rene',
I really appreciate what you've done here, and on your other databases. I noticed some p/n?? annotations for 08 models, and thought I'd pitch in:
Jam nut on Clutch Pack (all 08 models) p/n 7848W
Rear axle (all 08 models) p/n 41114-08
Hope someone finds that useful, and thanks again!
Jeff
Old Apr 20, 2010 | 03:52 PM
FXD2003Rider
Originally Posted by Ratbob
Rene',
Jeff
My pleasure, Jeff!
...I noticed some p/n?? annotations for 08 models, and thought I'd pitch in:
Jeff
Thanks for this useful info, Jeff; I've added the p/n's to the database.
I really appreciate your positive feedback and contribution to this thread.
René
Old Apr 29, 2010 | 01:07 PM
FXD2003Rider
Default info added
Based upon this thread I need to know the allen key size for st bob lowers by JRK5892, I have added some info on the allen head socket to the index.
This info was posted by SC-Longhair.
Thanks for sharing, Vic!
Socket, 1/2"; 12 mm; Impact; Hex Driver Metric; 6 Product Line: NAPA AirTools Part Number: NPT 615312
Old Jan 6, 2011 | 11:58 AM
Xube's Avatar
Xube
Rene, this data base is invaluable. I have no prejudice against metric measures- they are certainly more rational to use= but why metrics on a Harley? Anyone?
