***dyna models metric sizes database***
Old Jan 6, 2011 | 11:46 PM
  #31
ackman1968's Avatar
ackman1968
Rene, you never cease to amaze me! Once again you are going way to make our lives easier. Thanks!
Originally Posted by FXD2003Rider
This morning when I fired up my FXD2003 to go to work, I noticed the choke/enricher knop didn't stay out and slid back, so I decided to adjust it after I came home this evening.
Doing this, I tried a 5/8 wrench which seemed to be to small so I took a 11/16 which was just a little overzised.
Trying a 17mm wrench I discovered this nut is a hex nut 17 mm, so here's a new addition to the metric sizes database.
Wondering what size nut is used on the other Dyna models/years??
If you check and let me know I'll add your info to the database as well!
It was the same size on my 2000 Road King IIRC.
Originally Posted by Chris Webb
Rene, this data base is invaluable. I have no prejudice against metric measures- they are certainly more rational to use= but why metrics on a Harley? Anyone?
Showa forks are made in Japan for starters. Well, that's all I have.
Old Feb 13, 2011 | 09:02 AM
  #32
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
In this thread
Correct wrench to take off a 2006 Dyna rear axle nut
forum member johnnycocktails is informing us that "The correct wrench to take off a 2006 Dyna rear axle nut is 28mm..."
Both 2007 and 2006 use the same rear axle nut (item 2 in diagram below; p/n 8039).
I've added this info to the database:
rear axle nut p/n 8039 .................................................. .................... 28mm 6-point socket (added Feb. 13-2011) contribution of: johnnycocktails
Old Feb 25, 2011 | 01:20 PM
  #33
FXD2003Rider
Added new info based on this thread:
rear axle torque setting
2010 Models
2010 FXDWG
rear axle nut (p/n 8020) .................................................. ....... 36mm six point and torque it to 95-105 ft/lbs
contribution of:USMAMule (link) Feb. 25-2011
Old Nov 25, 2011 | 07:31 AM
  #34
FXD2003Rider
Bringing this database back to life and under your attention.
Old Dec 21, 2011 | 03:03 PM
  #35
FXD2003Rider
Default Axle size fxdwg 2010 front & rear 25mm
Added FXDWG front & rear axel sizes to the database.....
Originally Posted by Reaper_ggy
Anyone know what size they are ?
Front & Rear 25mm ? Am I correct ?
I wonder why all years are in inches and now in mm ?
thx
Originally Posted by thedonthere
yes 25mm is correct as for your 2nd question, we are one of only 3 countries in the world that don't use the metric system and it's about time we did...JMO
Old Feb 8, 2012 | 08:40 AM
  #36
FXD2003Rider
Default 2010 FXDC cap hex bolts
Added 2010 FXDC cap hex bolts info to the database:
Originally Posted by Gringoloco13
Can you add for the 2010 model that the same cap hex bolts are 5mm. I just had mine off for a swap two days ago. Didn't see it on your database but maybe I missed it, so if it isn't there please add.
Old Nov 4, 2012 | 03:38 PM
  #37
FXD2003Rider
Working on my clutch when I installed the ClutchWiz this week, I noticed all Big Twin 1998-2012 models pressure plate retainer ring use the same 10mm 12-point hex bolts (6) p/n 2980
Old Apr 4, 2014 | 06:38 AM
  #38
FXD2003Rider
Default Link to fastener specs
Useful link on fastener specs, posted by mattVA:
Originally Posted by mattVA
By accident I found that this particular dealer's OEM part finder lists fastener specs:
http://www.cyclecityltd.com/oempartfinder.htm#
Most online parts sites like Ronnie's HD do not always list the actual dimensions of a fastener when you find the PN.
Old Jan 3, 2015 | 03:32 PM
  #39
robbyville's Avatar
robbyville
These have been listed already with previous years but FWIW 2014 FXDB continues the trend of:
10mm hex bolts on the clutch spring retaining plate
35 mm fork cap
Old Jan 3, 2015 | 03:49 PM
  #40
FXD2003Rider
Working on my FXD '03 replacing the fork tube seals I noticed the fork damper screw needs an extended 6mm hex socket wrench:
SCREW M8 X 1.25 x 27 hex socket, p/n 45405-75A
