2007 wont start dynawide glide
Old Oct 21, 2009 | 06:24 PM
rob_1801964's Avatar
rob_1801964
Stage II
Default 2007 wont start dynawide glide
will turn over but wont start , washed the bike 3 weeks ago and didnt ride it and now wont start? any ideas
Old Oct 21, 2009 | 06:25 PM
Maimas's Avatar
Maimas
Did you happen to pull the plug wires off, or loosen them? Make sure they are connected properly
Old Oct 21, 2009 | 06:32 PM
jmpancoast's Avatar
jmpancoast
Three weeks is a long time for water to be an issue, but I would look at electrical connections, especially the plug to the ECM.
Old Oct 21, 2009 | 07:26 PM
rob_1801964
Stage II
Default where is the ecm plug
where is the ecm plug,, the spark plug wires are on
when you turn the ignition on i dont here it pumping is there a fuel pump?
Old Oct 21, 2009 | 07:41 PM
Maimas's Avatar
Maimas
The fuel pump will only prime when you turn on the ignition AND put the kill switch on run.
Old Oct 21, 2009 | 08:01 PM
TattoodCaptain's Avatar
TattoodCaptain
I had that happen on my '99. Turned out to be the Crank Position Sensor.
parrothead306
Sep 3, 2019 03:52 PM
bobbyjoes
Mar 14, 2015 05:27 PM
j.r.1982
Nov 5, 2014 07:54 PM
ranger_blackhat
Exhaust System Topics
Oct 19, 2008 11:40 AM
rdlc5501
Oct 1, 2006 07:27 PM
