n
Old Oct 1, 2006 | 06:52 PM
rdlc5501's Avatar
rdlc5501
Stage I
Default n
h
Old Oct 1, 2006 | 07:27 PM
glide's Avatar
glide
Default RE: 82 FXWG relay switch
Kind of vague from your description. If you had the wires out of the plug to replace the plug for the relay, is there a possibility that you put them back in the wrong position in the plug or did you get the wrong relay maybe ? If it fries the wire when you push start it, (are you referring to push starting the bike or pushing the start button here) I would then suspect a ground somewhere in that circuit.
Daddywags
Electrical/Lighting/Alarm
Sep 30, 2018 09:09 AM
GBHummer125
Jan 10, 2015 09:48 PM
kingjoey5000
Jun 14, 2013 01:38 PM
Ragnar Danneskjöld
May 1, 2013 10:30 AM
mississippiboy
Jan 21, 2009 10:59 AM
