Idle Cable
Old Oct 24, 2009 | 11:07 AM
efciv's Avatar
efciv
I also removed the return cable for a cleaner look. Yea, a free mod.
Old Oct 25, 2009 | 09:42 PM
fjm3rd's Avatar
fjm3rd
Originally Posted by CountryPunk
To have one less cable running up to your handlebars. Just cleans up the look slightly, and it's Free.
Ok Then why do they put it there in the first place if ya don't really need it. I thought it was there to make the throttle spring back to idle. If it's not there does the throttle still spring back to idle.
I got another question which actually happened to me last month. My throttle cable broke when thankfully I was only a mile from home. If this would of happened in the middle of no where would there be a way to rig it so that you could use the other cable if one of them broke, throttle or idle.
Thanks
Old Oct 26, 2009 | 07:10 AM
jcmusic's Avatar
jcmusic
Thanks
That's a good question my guess would be that if both cables are the same lenght, and the little ***** are the same size; you would be able to rig it to work. I don't know for sure never tried it!!!
Jay
Old Oct 26, 2009 | 07:21 AM
CountryPunk's Avatar
CountryPunk
Yes, you can swap them if one breaks. They are the same cable.
Old Oct 26, 2009 | 08:32 AM
Lone Watie's Avatar
Lone Watie
Default Back to idle
Thanks
I believe the 'pulley' on the throttle body is itself spring loaded which allows it allows it to spring back to idle.
Old Oct 26, 2009 | 02:53 PM
fjm3rd's Avatar
fjm3rd
Then if you don't need both cables and they are both the same maybe they put 2 on so you would have a spare when one of them breaks. But I know for a fact it would be a real pain to try to fix it on the side of the road with out a decent tool box along.
Old Oct 26, 2009 | 02:57 PM
fjm3rd's Avatar
fjm3rd
Forgot one thing the 90 degree bends that go into the throttle housing are 2 different sizes so maybe you can't switch them.
97HDSFTL
Sep 5, 2018 05:34 AM
morleyz
Mar 11, 2018 08:03 PM
obijohn
Sep 13, 2011 02:38 PM
big_e78
Sep 13, 2009 02:58 PM
carlo
Jun 24, 2008 08:32 AM
