Performance Machine 4-Piston
Old Nov 11, 2009 | 11:30 AM
rounder's Avatar
rounder
thoughts about performance machine and your 04. PM only sells brake kits for the 04-05 in chrome for the rear. If you want black or contrast cut, you can not match em. Hawg halters sells their brakes about 100 bucks cheaper, are easily as good, and you can go with black or chrome for both front and rear. Either way, you will improve your braking tremendously with the new calipers.
Old Nov 11, 2009 | 11:43 AM
Uquackmeup's Avatar
Uquackmeup
I'm running a 6 piston PM on front of my SB and really like it. Lyndall makes replacement pads, too. This caliper is an easy direct bolt on without any grief. They are pricey but you can find deals, if you consider $350 a deal on a single caliper.
Old Nov 11, 2009 | 11:47 AM
rounder's Avatar
rounder
where you find your deal at?
Old Nov 11, 2009 | 01:25 PM
Uquackmeup's Avatar
Uquackmeup
http://store.barnettharley.com/
Old Nov 11, 2009 | 02:07 PM
montey454's Avatar
montey454
I put hawg halters on my 04 deuce and they were a big improvement over stock. Another thing that made them better was putting braided lines on it.I put the calipers on then about a month later put the braided lines on and it stopped on the dime.
Old Nov 11, 2009 | 03:37 PM
blackmopar's Avatar
blackmopar
Originally Posted by Lama
I've used FabKevin's Tokiko kits before, they are common superbike calipers.
They stop better than anything Harley or PM produce, and are easy to get parts for.
He makes adapters for nearly any bike.
http://www.fabkevin.com/special_brakes.htm
Yea, Im planning to set up my rear with one of his dual caliper bracket kits after I set my front end up with dual discs - I am a proponent of the sport bike setups and pads are very easily found
AQA101
Mar 25, 2016 07:18 PM
JakeUSAF
2014-2024 Touring Models
Jan 1, 2016 01:06 AM
dgdamore
May 9, 2014 06:54 PM
Rebyl
Jan 1, 2011 09:03 PM
ppdl23
Apr 26, 2007 05:56 PM
