new exhaust gaskets
Old Nov 30, 2009 | 12:56 PM
davisnothere's Avatar
davisnothere
5th Gear
Default new exhaust gaskets
This is my first Harley. I always heard there were tricks to quite a lot of the mechanic work. I need to know what the trick is to installing new exhaust gaskets. The gasket is too big to fit in the head and too small to slip over the pipe. Even if you center them up and think you will squish them in with nuts and stud, there is not enough stud to know for sure that you will not cross thread the nut on the stud. I would think that the gasket has to fit in the head or on the pipe. I have an FXDB '09. ANY HELP WOULD BE GREATLY APPRECIATED. Right now I have the gaskets in the freezer hoping to contract them enough to slip them in the head. Am I on the right track or still lost?
Old Nov 30, 2009 | 01:51 PM
Blackpearlfan's Avatar
Blackpearlfan
I just changed out my exhaust on my 09 fat bob. I did not change gaskets out. Mine runs fine with no leaks. I have 5000 miles on my bike...
Old Nov 30, 2009 | 01:58 PM
CQCBlades's Avatar
CQCBlades
Did you get the old ones out first? I only ask as it took me forever to even notice that they were installed. Also did you get the regular replacement ones or the SE ones, the SE's are about a 1/3 of the size and recommended for V&H pipes.
Greg
Old Nov 30, 2009 | 02:02 PM
rounder's Avatar
rounder
yeah, I am wondering if you took the old ones out first. The stock gaskets shoud fit right in snugly, unless maybe the wrong gasket.
Old Nov 30, 2009 | 02:36 PM
Robottom's Avatar
Robottom
Assuming you're talking about the standard gaskets, and you've already removed the old ones, mine were a little tight going in too.
By the time I'd applied enough pressure to get the new ones started I had mushed the edges just a little bit. And that's just pressing with my fingers, they're really soft. But once they get started, resistance seems to drop off, just the initial getting the leading edge in was a pain.
Old Nov 30, 2009 | 02:40 PM
JRK5892's Avatar
JRK5892
gaskets should go right in man, not makeing it fit. i think you got the wrong gaskets there. i always use the stock ones over SE, gaskets are gaskets IMO...
ooh ya! with as cheap as they are i replace mine after every time the pipes are off the bike!
Joat Mon
Jul 27, 2011 10:08 PM
Dick1964
Exhaust System Topics
May 9, 2010 09:05 PM
Big Jon 1
May 7, 2009 08:56 PM
snooper0069
Apr 12, 2009 01:00 PM
ionate
Aug 30, 2007 02:19 PM
