Problems with strut cover removal!
Old Dec 8, 2009 | 05:54 PM
hddan502's Avatar
hddan502
Maybe, try to drill the head of the bolt off. I have done this a few time, but have not had to on my bike. Just drill a pilot hole in the center of the bolt a little deeper than the thickness of the bolt head. Then move to a larger drill bit. Repeat until the hole gets large enough and the bolt head will come off, from the stud of the bolt.Then you can remove the strut cover, spray with WD 40 then grab the remaining stud with some vice grips to remove. Go slow patience is required. Good Luck!
Old Dec 8, 2009 | 06:58 PM
Phrogman's Avatar
Phrogman
Go to a Sears and get an easy out set. Just ask the tool guy and he'll hook you up.
Old Dec 9, 2009 | 01:51 AM
BamaBoyjc's Avatar
BamaBoyjc
Since I work on Helicopters we have this problem ALOT with screws and bollts.... One trick is like one post said take a file and file a straight slot into the head for a #2 or #3 Flathead screwdriver. This sometimes works but depending on how good ur screwdriver is...I've broken quite a few SnapOns at work. Also, there is this compound that we call easyout (can't remember technical name) but essentially it's just a tacky gel-like substance with grit in it. Put osme in the hole and then it fills the hole to where ur Torx head will fit and grab. An easy trick to that instead of buying some is to just spit on the torx head and put it in the dirt to coat it good. Works just as well. Also, an actual bolt-out or screw-out kit works really well. They are better than the old Easy-out kit. Hope this helps. Like one guy said, you could drill off the head but I'd try these things first since soemtimes it's a pain in the *** using the vice-grip trick. You might not have enough to grip since you said you didn't even budge the bolt. I've done that one before too!
Old Dec 9, 2009 | 06:08 PM
stic2it's Avatar
stic2it
Well, luckily for me my bolt came half way out and then stripped, so I was going to try the vice grips first. That white stuff harley put on there is a pain in the *** to remove. I just haven't tried it because I don't have the replacement bolts yet, so I didn't want to go ****ing with it yet.
I will definately keep your hints in mind and go get me an eazy out kit soon! I see me needing it pretty often!
Old Dec 9, 2009 | 07:46 PM
Phrogman's Avatar
Phrogman
Dude, I completely forgot about that trick! You can use Comet cleaner as well, just wet it a bit to make a paste and pack the bolt head. Works just as well.
Old Dec 9, 2009 | 08:13 PM
clicker01's Avatar
clicker01
Yeah wrong size torx. I know that now. But how do I get it out? I have the same problem except I stripped it without even moving the bolt at all. How can I get it out?
I had the same thing happen with the Autozone torx bits. They're junk! I went to Sears and bought a set of Craftsmans. Even tho the bolts seemed stripped, the Craftsmans pulled them out no problem . Good luck!
Old Dec 10, 2009 | 12:56 AM
Tat2u's Avatar
Tat2u
make sure you run a tap through the threaded holes again before fitting bolts back into them
Old Dec 10, 2009 | 03:08 AM
BamaBoyjc's Avatar
BamaBoyjc
Phrogman...I forgot about that as well. I think it sometimes works better. Essentially it's all the same concept.
Snooplbc
Sep 10, 2015 08:11 PM
AZRider62
2014-2024 Touring Models
May 15, 2014 09:32 AM
murd
Dec 9, 2013 09:58 PM
Cowboy Rob
May 3, 2010 01:44 AM
menderle
Sep 21, 2005 02:27 PM
