HID conversion kit, thinking of pulling the trigger
Old Dec 8, 2009 | 11:25 PM
Hickey's Avatar
Hickey
Default HID conversion kit, thinking of pulling the trigger
I've done a lot of searching, a lot of comparisons, and it seems as though I've decided on an HID kit for my street Bob.
http://www.xtralights.com/xetronicdi...ypesingle.aspx
I was wondering if anyone has had experience with this kit? I've pretty much come to the conclusion that I will try to mount it to the frame on the brake side of the backbone (ballast only 1/2 inch thick). If it doesnt fit there, I'll just mount it to the bottom of the tank on the same side (in the large tank indent). I've talked to their customer service and they said its 100% plug and play.
My questions are, if you've had experience with this kit, does it simply plug into the multilock connector for the head light to supply the power for the ballast? and is there really any point in going with the bi-xenon bulb for high and low function (does it still operate with the handle bar switch? Also, am I looking at a night and day difference between HID and stock?
I've already tried the sylvania ultra bulbs, but it didn't cut it, at all. Better than stock, but still poor.
Let me know!
Connor
Old Dec 9, 2009 | 02:05 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Ask about the measurements and than mock it up. Ask yourself if that is what you wish to hang of of your bike. I have done many of them and I do not wish that type of physical set up. save your self some time and mock it up prior to purchasing. You can get a kit with the ballast hidden between the gas tank and frame, Search the posts here and you can see the photos.
Mchad
Mar 6, 2016 08:43 AM
Timpsonsoldier
Apr 3, 2014 03:45 PM
BCISCO513
Jul 27, 2012 10:42 PM
JBoggs
Jun 10, 2011 06:48 AM
CrossRKC
May 14, 2009 08:06 AM
