Easy pull clutch gizmo
Old Dec 12, 2009 | 06:35 PM
rounder's Avatar
rounder
got the snap ring pliers. I have to change to a longer cable when my new risers arrive, I figured while in there maybe install the burly kit, might be nice to have a softer pull. If it is really junk, I'll leave well enough alone. If it works fine.... then I'll probably get it. I am not going to be installing the Harley one, no compressor tool for the removal of the stock spring.
Old Dec 12, 2009 | 09:06 PM
mtairy biker's Avatar
mtairy biker
you don't need any special tool just like a 1/2 or 7/16 wrench on that side thats it!!! simple job the other side is more of a pain in the ***. but it is a easy job over all
Old Dec 12, 2009 | 09:26 PM
WS6 Formula's Avatar
WS6 Formula
http://www.harley-davidson.com/en_US...ts/-J02960.pdf
Old Dec 12, 2009 | 10:28 PM
BoomerBob's Avatar
BoomerBob
Something to remember when you do this job on the right side of the trans - it doesn't hurt to have an extra gasket. Mine was ok so I reused it but it was a James gasket. If you put the front and rear wheels on 2x4 boards and lean it on the kickstand the night before then you will probably have very little oil loss out of the trans when you take the cover off. Also; If you don't already have the correct short shoulder allen wrench for the bolts then you should try to find a set (I found them on Amazon I think). It will make your job much easier if you don't have to move the exhaust pipe. They may have the size you need here.
Old Dec 12, 2009 | 10:33 PM
MZBuckeye's Avatar
MZBuckeye
Originally Posted by WS6 Formula
I would assume you have a 2005 or earlier Dyna, if that is the case see how a 2006 and up Dyna clutch pull feels. Below is the link to the kit that is factory installed on the 2006 and up models.
Reduced Effort Clutch Kit
Kit includes a new clutch spring and inner/outer ramps that significantly reduce clutch lever effort. Original Equipment on '06-later Twin Cam-equipped models.
36808-05
Fits '99-'05 Twin Cam-equipped models. Stock on '06-later Twin Cam-equipped models. This kit is not compatible with Screamin' EagleŽ Performance Parts.
MSRP US $44.95
http://www.harley-davidson.com/gma/g...bmLocale=en_US
I had this installed in my bike when I had my throwout bearing replaced. I couldn't believe how different it felt. Highly recommended.
Old Dec 13, 2009 | 09:10 AM
rounder's Avatar
rounder
so when texas speed freak said I need a compressor tool to compress and remove the stock spring, That was incorrect? I reviewed my service manual and it looks like the spring comes apart simply by removing the six bolts in a star fashion then just remove the retainer, remove the spring, replace spring and bolt it all back up. One thing the service manual does not state is whether or not the clutch pack adjuster should be released (loosened up)before doing this.
Old Dec 13, 2009 | 09:42 AM
Wireguided's Avatar
Wireguided
This is what i did..
And it works very well..
http://www.rekluse.com/torqdrive2.shtml
Old Dec 13, 2009 | 05:54 PM
mtairy biker
thats right 6 little bolts some bule locktight addjust the cluch with the alen and 11/16 than do the barrel nut on the cable and you are done buttn up primary add fluid
arnie54
Aug 31, 2017 11:51 AM
Hey Man
EVO
11
Jul 8, 2017 03:28 PM
nukie
EVO
11
Dec 18, 2016 11:51 PM
Ron750
Nov 20, 2015 10:33 AM
Jeff's 1st Harley
Nov 28, 2013 07:46 AM
