Epoxy Paint - Looking for Knowledge
Old Dec 23, 2009 | 06:52 PM
jousley's Avatar
jousley
Default Epoxy Paint - Looking for Knowledge
I've read JRK's post on epoxy paint and the lower forks.. looking for some knowledge
1) Obviously powder is better - but for the coin - if you do it right, is epoxy a good alternative?
2) how long does it last?
3) is it easy to remove? If you F up or change ur mind?
4) what parts are the best to use epoxy for? battery band? struts? wheels? bars? mirrors? crash bar?
5) JRK, in your writeup you said use 220 sand paper until you "get a good line".. can you explain in more detail the prep process.
thanks all
J.
Old Dec 23, 2009 | 09:07 PM
JaronB's Avatar
JaronB
I've had mine for about a year and still looks good. I think JRK had his painted 3 years ago. When you sand it with 220 is to get the clear coat off. Then take 400 and make fine. Clean it and paint it. Make sure the temp of where you are painting is above 55 degrees and you need to get 5-6 coats on there pretty quick. First coat do a light tack. Read the directions on the can. If I remember right it was 5 min between coats, but not to exceed 30 min otherwise it will turn wrinkly. Make sure you cover everything in your garage you don't want over spray on because the paint carries. I got some on my fender and windshield 20 feet away. Don't forget to cover the bike completely also.
220 Grit
400 Grit
Final
Old Dec 23, 2009 | 09:11 PM
JaronB's Avatar
JaronB
Oh and do not touch it for 24 hours no matter how big of an urge you get (don't ask). Here's another pic. If you screw up you can sand it back down and start over. If you get chips in the paint just get the touch up paint for it.
Old Dec 23, 2009 | 09:27 PM
JRK5892's Avatar
JRK5892
well said!
Old Dec 23, 2009 | 09:30 PM
JaronB's Avatar
JaronB
Originally Posted by JRK5892
well said!
I was edumacated by you!!
Old Dec 23, 2009 | 10:26 PM
BLKBAGGER's Avatar
BLKBAGGER
JaronB That turned out great. Good job. It's got a good gloss to it also.
Old Dec 23, 2009 | 11:01 PM
JaronB's Avatar
JaronB
Thanks! I learned it from this site. There are a bunch of people doing this and it only takes on $15 ratle can. It's not as shinny now but still has a semi gloss, but nothing that just anybody will notice. A little wax shines it back up!
Old Dec 23, 2009 | 11:18 PM
rounder's Avatar
rounder
also after about 5 days, to get that killer deep shine, 2000 grit wet sand, then high speed polish em out. Big difference in the final product. Use a microfinishing glaze or fine cut cleaner to bring the shine back after sanding.
Old Dec 25, 2009 | 02:00 AM
jousley's Avatar
jousley
can u use this same method for like the battery band... electrical cover? what is the best prep method for this?
J.
Old Dec 25, 2009 | 02:09 AM
Nightking's Avatar
Nightking
J.
If you're talking chromed parts, you just need to make sure you have the chrome scuffed down to where it is completely flat looking. In other words, so you can't see yourself in the chrome. Then, you are ready to start your process of painting.
