Just installed lights on my engine guard
Old Sep 24, 2010 | 08:18 PM
  #31
user 8373900's Avatar
user 8373900
I put some on my Wife's Superglide Custom now she has better forward lighting than my Ultra! Those little buggers are bright!
Old Sep 24, 2010 | 09:23 PM
  #32
Mike Horrell's Avatar
Mike Horrell
One Up; which lights did you install?
Old Sep 24, 2010 | 09:26 PM
  #33
user 8373900
Those same ones from HD the oval ones..Bright little suckers.
Mark
Old Sep 24, 2010 | 10:08 PM
  #34
SUPER01's Avatar
SUPER01
Originally Posted by HogNewbie
For those who want this is what the fogs look like with the wires run through the bars.
shows wires coming out of the bars
The wires that came on the harness are too short, so I pulled back the plastic shield, cut and reconnected the wires and hid the connectors inside the shield.
Next I drilled three holes. One under each of the light mounts (the underside of the bars) and one in the center. I inserted a rubber grommet inside each of the holes to protect the wires. (grommets you can get a Lowes/Home Depot for like 35 cents each.)
Using a piece of shielded wire (to avoid scratching) I fed from the light holes to the center hole and pulled through.
I then simply mounted the lights and strapped up the harnes to the frame using the supplied black tie wraps and was done. Approx time maybe 1 1/2 hrs.
Nice job!
What size hole did you drill to run the wires?
Old Sep 25, 2010 | 07:38 AM
  #35
Mike Horrell
Mark
Thanks. I may switch over at some point.
Old Sep 26, 2010 | 09:59 AM
  #36
HogNewbie's Avatar
HogNewbie
Default hole size
Originally Posted by SUPER01
Nice job!
I don't remember what size they were. I went to Lowes and went through their grommets. I picked one to where the ID was just big enough to get the wires through. I measured the OD, pre-drilled with a tiny drill and then re-drilled with the larger. If I had to try and guess I would say the OD was no bigger than 3/16", 1/4" at the most.
Oh don't forget to tape off first to stop the drill slipping. Drilling a bar is not the easiest. I forgot the tape on one hole and the drill just skidded and scratched the chrome luckily enough it was under the light mount.
Good luck
Old Sep 26, 2010 | 12:01 PM
  #37
Rusty Nail's Avatar
Rusty Nail
Finally got mine installed. I ran the wire from the fuse to the positive battery side and the unterminated wire to the accessory fuse box. I can have the lights on with either low or high beams on. Thanks FXD2003 Rider for all your help.
Attached Thumbnails Just installed lights on my engine guard-blue-fat-bob-025.jpg   Just installed lights on my engine guard-blue-fat-bob-026.jpg   Just installed lights on my engine guard-blue-fat-bob-027.jpg
Old Sep 26, 2010 | 12:28 PM
  #38
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Glad you got them working now, Conrad.
I guess the wire connections and loops in the images are in the "experimental phase"....If not, IMO you're asking for trouble on the long term!
rebbe18
Nov 29, 2013 11:33 AM
Mike Horrell
Feb 3, 2010 02:56 PM
Barberg
Jul 6, 2008 12:38 PM
jasonyankees
Mar 31, 2008 08:25 PM
BarryN
Sep 23, 2005 12:17 AM
