fxr troubles
Old Jan 5, 2010 | 09:42 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Originally Posted by becker105
ok thanks for the replies i guess ill try these and aviod going back to the shop
Be sure and let us know what resolves this.
Old Jan 5, 2010 | 06:32 PM
96 Wide Glide's Avatar
96 Wide Glide
Another possibility is your timing pickup is on it's way out. They often will start going when the motor gets up to temp, before they quit completely.
Old Jan 5, 2010 | 07:12 PM
Scooter-Dog's Avatar
Scooter-Dog
Gunk in the tank I bet. I had an '89 FXRS that did that until I sealed the inside of the tank and put a clean petcock / filter in.
Old Jan 5, 2010 | 08:07 PM
becker105's Avatar
becker105
3rd Gear
allright so far i have ruled out the coil and most of the electrical stuff. i have an aluminum tank that is pretty clean, petcock is now non vacuum and working. so it must be carb problems, im taking the bike to a friend who knows more about it than i do. i guess in a couple days ill find out
Old Jan 5, 2010 | 08:09 PM
becker105's Avatar
becker105
3rd Gear
quick question. how do you check the timing pick up and how do i know its bad??
Old Jan 5, 2010 | 08:28 PM
96 Wide Glide
You could try removing the cover and gasket, heating the pick-up with a heat gun, then try starting the motor. If it starts, mabe keep the heat on it a little longer, see if it shuts down.
Old Jan 11, 2010 | 07:38 PM
becker105's Avatar
becker105
3rd Gear
carb pins and pin seats. i dont know what this does all i know is carb was not feeding gas properly. mikuni you are out s&s on the way, should be here tomarrow and running by friday. rocknroll
HDCrossbones09
Aug 9, 2017 05:32 AM
Stiched
EVO
75
Jun 13, 2016 07:15 PM
0maha
EVO
11
Jul 17, 2014 09:31 PM
nick@nite
Motorcycles For Sale
11
Mar 8, 2014 09:24 AM
CVance
May 23, 2011 04:04 PM
