simple question
Old Jul 19, 2006 | 09:28 AM
Ash's Avatar
Ash
Default simple question
I didnt buy the manual yet, so how many qts of oil does a street bob take?
Thanks! And I seached, I saw 2 1/2 one place and 3 another.
Old Jul 19, 2006 | 09:40 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Default RE: simple question
2.5qt. in the engine oil tank, 1qt. in the primary, and 1qt. in the trans.
Old Jul 19, 2006 | 09:51 AM
jt1965's Avatar
jt1965
3 qts if you change the filter.
Old Jul 20, 2006 | 09:06 AM
Ash's Avatar
Ash
Thanks you guys!!!
Old Jul 20, 2006 | 10:07 AM
06dynablack's Avatar
06dynablack
06 fxdi takes 2.5 qrts with filter change
Old Jul 20, 2006 | 10:09 AM
HOGRIDA_06's Avatar
HOGRIDA_06
ORIGINAL: jt1965
This is not true, 3qts. only if engine is disassembled and cleaned. 2.5 qts. is the right amount. Too much and oil will leak out of the air cleaner.
Old Jul 20, 2006 | 01:51 PM
voyager1's Avatar
voyager1
mine too 3 qts on the money,then again,i let it darin real good overnight : i am right @ the full mark . i actually think it drains better cold. all the oil is at the bottom. just my thoughts .
Old Jul 20, 2006 | 02:01 PM
jw5150's Avatar
jw5150
just double checked manual.......3 quarts if motor is completely broke down and dry. Just 2.5 with oil and filter change.
Old Jul 20, 2006 | 05:47 PM
scotch's Avatar
scotch
split the diff..
2.75
Old Jul 20, 2006 | 05:50 PM
JamieWG's Avatar
JamieWG
Just change the filter, drain the oil, then dump in 2.5 qts and read the dipstick. If it's low, add more.
OGBlackout
Jul 6, 2018 02:31 PM
Iron2fatbob
Apr 25, 2016 11:14 PM
kel03
Engine Mechanical Topics
Dec 13, 2015 12:23 AM
cdaxj
Apr 4, 2009 09:54 PM
lostrider06
Aug 14, 2006 02:56 AM
