Battery Removal
Old Jan 13, 2010 | 09:46 AM
bbqbrisket's Avatar
bbqbrisket
Default Battery Removal
I don't get it.
According to the service manual.
Unscrew lower bolt and loosen upper bolt on the left side of the battery case.
Battery tray will drop down.
Seems pretty clear to me.
Well, it don't drop down.
Any ideas why it's not happening for me?
btw, I notice a black 3 inch strip of rubber above the top chrome cover. Is this suppose to be loose from the the chrome cover and attached to the frame or is it suppose to be attached to the chrome cover cap with some sort of glue?
Old Jan 13, 2010 | 09:51 AM
glideridemike's Avatar
glideridemike
whatcha ridin?
The year and model does make a diff.
On my '03 WG I have to also loosen the back tray bolt and take the front one (bolt) off to get the tray to tip down allowing the battery to clear the frame. Just don't let the neg and pos terminals touch the frame at the same time or its going to be a mini fireworks display....could cause harm to electronics or the battery if ya do let them both touch.
Old Jan 13, 2010 | 09:54 AM
bbqbrisket's Avatar
bbqbrisket
OH yes
05 wide glide
Old Jan 13, 2010 | 09:57 AM
glideridemike
Might be the same basic technique.
Old Jan 13, 2010 | 10:35 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's a parts diagram from the FXD 2003 set-up. I hope it's the same on your bike.
The top cover should be held by the cushion, battery when the tray is mounted way up by screw 4342 and secured by screw 4383.
Take care not to unscrew 4342 totally, it has a small flange at the end!
FXD2003Rider
Old Jan 13, 2010 | 10:39 AM
bbqbrisket's Avatar
bbqbrisket
AH HA,
I get the top cushion...thanks.
I finally got it loose. It appears that it doesn't just drop, you have to kind of push up and then down a little to loosen it up..
thanks again
Old Jan 13, 2010 | 04:23 PM
Taddeoeg's Avatar
Taddeoeg
Yeah, was a bitch getting the batt box off my s/o's 2000 FXDL. We replaced it with the rounded, one-piece style cause the corner was digging into her thigh. Onepiece is much easier to install and take off.
Glad you got it figured out.
Old Jan 13, 2010 | 06:56 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I was going to tell you that it takes a little shaking and movement to get the tray to drop down. Another little trick, take a real cheap 10mm box wrench, heat it up real good and put about a 45 degree bend in it about 3/4 to 1 inch from the box. This makes the cable mounting bolt much easier to access and remove.
Rebyl
May 23, 2010 06:38 PM
bbqbrisket
Jan 13, 2010 09:52 AM
wideone
Mar 21, 2008 07:13 AM
Jimbo59
Jun 3, 2007 04:56 PM
kenn101
Apr 5, 2006 03:10 AM
