Head/cam question
Old Jan 13, 2010 | 11:19 PM
roadgliderick's Avatar
roadgliderick
Originally Posted by vinsil
thank you very much steve for the scan. They look like very aggressive and strong cams, look forward to seeing your results.
Don, i really don't want to change springs...i will call the dealer and ask about the 54's and go from there. If they won't do it, i will just buy them and do it myself. thanks a bunch all, you all helped a ton.
the valve springs only cost $150.00 u can do it . Good luck
Old Jan 14, 2010 | 12:04 AM
yso191's Avatar
yso191
Originally Posted by streetgliderick
check my post i just did a big bore with 259e cams. Hp 91.10 tq 101.7. Iam asking for everyones opinion and so far i have been told the numbers should be higher. But the rideabilty is great it has great torque and pulling power. But i have true duals the tuner said put 2 into 1 thunder header and the nubers will go up. I like it the way is. Anyway check it its on here.
Rick,
Glad to hear you like the cam grind. Can't wait to get mine done!
Steve
scuba_steve
Engine Mechanical Topics
27
May 20, 2021 06:37 PM
Tupp
Aug 10, 2018 09:44 AM
Gutter Man
Apr 8, 2010 05:49 PM
bigbean78
Jul 18, 2009 05:13 AM
d.dimperio
Exhaust System Topics
23
Mar 17, 2008 01:29 AM
