Turn signal relocation
Old Jan 16, 2010 | 09:21 PM
streetbob09's Avatar
streetbob09
Default Turn signal relocation
Who makes the best relocation kit for the front on an 09 streetbob definatly wont use that stupid looking HD kit any suggestions or pictures of them installed
Old Jan 16, 2010 | 09:45 PM
RKKY's Avatar
RKKY
Went with the Biker's Choice set-up on my FXD. Less than 20 bucks.
Old Jan 16, 2010 | 10:07 PM
Karsten's Avatar
Karsten
Drag Specialties makes a couple good kits. One mounts to the upper or lower triple tree with the curved mount to keep them in close. I used this set on my 1998 Sportster with 39MM tubes and it worked out great. Not sure they have it for the 49MM forks thought.
The other is a stud that replaces the triple tree bolt and has a pivot, ball and socket sorta set up that will work on hte 49MM forks and your factory lights.
I had the guys do it while it was in for a service and they used a kit listed on my sheet as
39 & 41MM Fork Bull at $28.99.
They are tucked in close and solid, far better than the clamp on stuff I had tryied in the past.
By null at 2010-01-16
Karsten
Old Jan 16, 2010 | 10:20 PM
freddyttt's Avatar
freddyttt
I went with these.... a tad more money i guess but they work well and stay close.
http://www.kuryakyn.com/index.cfm/go...etail/IMID/711
Old Jan 16, 2010 | 11:28 PM
Hickey's Avatar
Hickey
I did this, gets them off the front end entirely. Really cleans up the front end, plus it looks pretty badass tucked under the forwards. If you dont have forwards, you can still mount it up to forward mounting holes on the frame.
https://www.hdforums.com/forum/dyna-...rols-done.html
Old Jan 16, 2010 | 11:38 PM
OhioSkully's Avatar
OhioSkully
I went with the BKrider stuff on ebay very happy with it.
http://cgi.ebay.com/ebaymotors/49mm-...Q5fAccessories
heres a pic on my bike
Old Jan 17, 2010 | 02:12 AM
jmpancoast's Avatar
jmpancoast
I stole my relocation set-up from the "Under 50 Bucks" thread.
Old Jan 17, 2010 | 11:43 AM
nevil's Avatar
nevil
I also used the Drag Specialties mounts. They do stay close to the forks. Got them from Dennis Kirk for $19.99, and they make them for 49mm. Don't have any pics but you can enlarge the parts in the listing.
http://www.denniskirk.com/jsp/produc...Id=212839&mmy=
Old Jan 17, 2010 | 11:47 AM
Joe376's Avatar
Joe376
These are the same ones I used. Only thing about these though, the bolts it came with didnt match the thread of my stock signals. Had to buy new bolts. Now Im thinking about taking em off the forks all together and mounting them somewhere else.
Old Jan 17, 2010 | 02:02 PM
Toplink's Avatar
Toplink
Default Found this for ya
http://ae1m.com/relocate_directionals/install.htm
That's the one I ordered and should be installing it tomorrow.
http://www.phatperformanceparts.com/...47&click=37735
