Running into a Problem
Old Jan 18, 2010 | 06:07 PM
JaronB's Avatar
JaronB
Originally Posted by Fupl18
oh ok.. No i never need to install one of those :P..
So that isnt the problem.
Well if you don't have the module, check your fuses then brake switches. Other then that I'm dry, good luck!
Old Jan 18, 2010 | 06:24 PM
Fupl18's Avatar
Fupl18
I have checked the front brake switch.. Looks like it is working properly (pushes in and comes out). But as far as the rear brake switch i have no clue where to find it.. i did trace the wires all the way down to it and the connectors are good.
Taking out the light bulb from the stock housing.. Tool>>> or just push in them black tabs>>>
Old Jan 18, 2010 | 08:26 PM
A-10 KChawg's Avatar
A-10 KChawg
The same thing happened to me. I read and read and read (including the HD maintenance manual) on how not to F-up the brake switch when replacing the brake lever. When I was done, it functioned fine mechanically (all in one piece). But took it in for an ispection the next day and had to get it replaced. The first question they asked was "did you replace your brake lever yourself?" That switch is waaaaay fragile I guess.
Old Jan 18, 2010 | 09:16 PM
Fupl18's Avatar
Fupl18
That might be it then.. I guess i will just take it in tom and see what they bill me..
Old Jan 19, 2010 | 06:15 PM
A-10 KChawg
So, what's the word? Is it fixed?
_allergic2u
Sep 7, 2016 07:22 PM
jackyl
Jul 30, 2016 04:34 PM
FastEddie1200
Electrical/Lighting/Alarm
Oct 30, 2014 02:59 AM
smokinwill
Feb 23, 2014 04:35 AM
Sallyman
Jun 27, 2011 06:12 PM
