No brake light??
Old Jun 24, 2011 | 05:54 PM
Sallyman's Avatar
Sallyman
Default No brake light??
My wife was behind me the other day and told me I had no brake light?? So I checked and sure enough I don't. When I turn the key on all the tourpak lights come on along with brake light - it stays on all the time so I left the key off and tried the brake and the light won't come on?? I changed the bulb but same thing, anyone have an idea?
Old Jun 24, 2011 | 06:22 PM
mmcbeat's Avatar
mmcbeat
With the lights on, the tail light should get brighter when you apply the front or rear brake. I recently had to replace the rear stop light switch.
Old Jun 24, 2011 | 06:36 PM
piasspj's Avatar
piasspj
Brake light always on, check for a stuck switch (either front or rear.. No brake light with either front or rear brake, check bulb, fuse, wiring.
Old Jun 24, 2011 | 08:58 PM
asm481's Avatar
asm481
Had your right grip switches open for anything? If you open that side up without a spacer in the lever you broke the switch off.
Old Jun 27, 2011 | 06:12 PM
Sallyman's Avatar
Sallyman
found my issue - front brake lever wasn't seated properly, spacer was still there. Must have happened when I changed grips and just didn't notice. I guess this would explain why my cruise wasn't working as well??
jackyl
Jul 30, 2016 04:34 PM
Briguy1
Electrical/Lighting/Alarm
Feb 9, 2015 06:10 PM
Benway
Sep 15, 2012 05:50 PM
HemiGlide69
Feb 17, 2012 06:38 PM
SIDEWAYZ50
May 23, 2006 08:32 PM
