Help!! 09 FXDC Replacing Buckhorns with 12" Apes
Old Feb 23, 2010 | 10:43 PM
wattsupFXDC's Avatar
wattsupFXDC
Default Help!! 09 FXDC Replacing Buckhorns with 12" Apes
I am getting ready to replace the stock buckhorns with 12" apes. Do I have to remove the tank to replace/extend control and throttle cables? I plan to run cable internal to bars.
Old Feb 23, 2010 | 10:49 PM
archergodwin's Avatar
archergodwin
Nope, just unbolt it so it will slide back a few inches.
So... are you calling your wires "cables"... referring to the 'cable' you plan to run internal to your bars... ?
Old Feb 23, 2010 | 11:09 PM
cptdenny's Avatar
cptdenny
I had mine done, (mini apes) last week by the dealership. Good news, the contol wires/harness doesn't have to be replaced or spliced on the '09 FXDC.
There's enough length with the stock harness under the gas tank for mini ape bars. The brake cable and throttle cables were exchanged for longer ones. The signal lights weren't relocated, so no problem with those wires either.
Old Feb 23, 2010 | 11:27 PM
archergodwin
If you had the HD mini-apes, then yes... but they are only 10.5 rise at best. With a true 12" rise, you will probably need longer wires and cables.... but it also depends on how wide the bars are.
I installed the HD fat mini-apes and and went +4 with the Barnett cables. They are 10.5 rise on top of 4" risers.
Old Feb 24, 2010 | 11:26 PM
wattsupFXDC
Red face Question on control wires and handlebars
Thanks for the info. Would you recommend to run the control wires internal within the bars than exposed? I think the wires being hidden provide a cleaner look. What handlebar manufacturer do you recommend in 12" apes.
Old Feb 25, 2010 | 08:15 AM
SC-Longhair's Avatar
SC-Longhair
Running wires internally is purely a preference issue. I would, but you may not want to.
Going from 10.5" bars to 12" bars? Get down wit yo bad self. lol just kiddin.
tbonetony06
Dec 6, 2012 03:31 PM
CB1
Nov 15, 2011 03:12 PM
dynhd1
Mar 30, 2010 12:21 AM
Subvamp
Mar 28, 2008 09:30 AM
gollnerr
General Topics/Tech Tips
Feb 26, 2008 10:32 AM
