Taking off the reflectors???
Old Jul 27, 2006 | 11:12 PM
memrep's Avatar
memrep
4th Gear
Default Taking off the reflectors???
Wanna take them off!! Whats the way to do it?? Someone suggested dental floss. Is that the trick? I guess I'd heat it up the sticky stuff with a hair dryer or something. I got the demin black Bob, would the paint be OK?
Thanks.
Old Jul 27, 2006 | 11:21 PM
rogue_rob's Avatar
rogue_rob
Default RE: Taking off the reflectors???
I asked the dealer that question and the bastards tried to sell me a new set of forks and a rear fender without the reflectors[:@][:@][:@]
Old Jul 27, 2006 | 11:24 PM
jw5150's Avatar
jw5150
The weather here in PA has been real hot and humid. I have black cherry bob. I set it out in the sun and let it heat up and the reflectors just pulled off. There was a little bit of the glue left on which cleaned off pretty easy with WD40. Then washed and waxed bike. If you use the WD40 make sure you don't get it on rear brake. I covered mine with plastic bag just in case some dripped down. Looks better with them off. Good luck
Old Jul 27, 2006 | 11:25 PM
jw5150's Avatar
jw5150
Might have to use slightly different method with denim. Not sure how WD40 will be on it. Also no waxing on denim from what I hear.
Old Jul 27, 2006 | 11:40 PM
16over's Avatar
16over
Check out the following link
https://www.hdforums.com/m_313104/tm.htm
Old Jul 28, 2006 | 01:34 AM
but Ill try 2 try's Avatar
but Ill try 2 try
With denim paint you could probably use carb cleaner. That stuff will make the glue easier to clean than any other spray. I used dental floss which broke and then used some 10 lb test fishing line. What's your address? I'll send you a few inches.
I used a combination of goo gone spray, wd40, and carb cleaner, I tried to be easy with the carb cleaner on the clear coat, but that glue/tape was tough even in the hot sun and humidity.
Old Jul 28, 2006 | 01:39 AM
BeavisRules's Avatar
BeavisRules
I used a hair dryer to heat the reflector and then dental floss to gett hem off (they literally fell off after heating them up).
I worked the glue off with my finger (rolling it into a ball) and then a little soap and water to get the rest off.
Looks alot better.
Old Jul 28, 2006 | 02:32 AM
CraigC's Avatar
CraigC
Personally, I don't think the dental floss or fishing line method is worth the effort. Just peel them off. Same goes for the tank emblems. Just mask off the end opposite where you're lifting to avoid it scratching the paint. If the adhesive stays on the paint and won't easily peel off, 3M Adhesive Remover.
Old Jul 28, 2006 | 03:09 AM
Babe's Avatar
Babe
I soaked mine with white spirit applied with a brush, allowed it to soak in for about 20 minutes - time for a cold one - before pulling/twisting them off by hand.
Old Jul 28, 2006 | 03:23 AM
memrep's Avatar
memrep
4th Gear
Done!
I just heated them up with a hair dryer, and peeled them off.. Some WD-40 on the sticky stuff, and clean it up with windex.....
Man it looks sweet!!
