BCT Baffle Question
Old Mar 12, 2010 | 09:45 PM
Topspin's Avatar
Topspin
Default BCT Baffle Question
Will a Big City Thunder Baffle fit in a Screaming Eagle Slip on with the removable baffles?
Old Mar 12, 2010 | 10:21 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
On some SE slip ons yes, but pull one out and measure OD and length and call them just to be sure.
Old Mar 13, 2010 | 05:01 AM
cactusred's Avatar
cactusred
Yep, I have em on mine for an 06 dyna. The only thing I did do was cut about 3/8 inch off the length of the new bct baffle, and the only reason I did that was they were just a little I think where the holes were predrilled to attach to the slipon itself, so I didn't really want to drill two additional holes just to make it work.
Old Mar 13, 2010 | 08:32 AM
gman's Avatar
gman
i have SE IIs on my '06 WG. Simply removed the two bolts holding the baffle in, removed the baffle and inserted the BCT baffle. took me about 20 minutes, which included a can of beer and BSing with the buddies.
Old Mar 13, 2010 | 09:15 AM
Sonny's World's Avatar
Sonny's World
To what degree and in what way does the switch to BCT baffles improve the sound of the older SEII's? I think my bike sounds pretty good now, certainly better than a stock exhaust. Just curious if it really makes a difference and is something I should want to do.
Old Mar 14, 2010 | 07:55 AM
Sonny's World
How much better will non-EPA SEII slip ons sound with BCT baffles?
Old Mar 14, 2010 | 10:07 AM
cactusred's Avatar
cactusred
I don't think there would be any difference. You have to remove the current baffle in the epa restrictive baffle (I'm guessing post 06) and remove the non restrictive epa baffle (I'm guessing pre 06), so your left with a hollow shell that you slip the new bct baffle in, so should be no difference in sound at least from the muffler. I have an 06, and I bought my seII's slip ons in 08, I put em on brand new stock and they sounded identical to the stock cigar tapered mufflers that were on the bike, like a sewing machine. So that's when I yanked the scII baffs and put in the bct. The only probably real difference would be the mounting of it, I think they change the muffler mounting around from model to model and some years too.
Old Mar 14, 2010 | 11:29 AM
HDDyna2006's Avatar
HDDyna2006
I mod SEII baffles by opening them up a Bit,
save the money for a new system, just take baffles out and open the front flat a bit, sound will increased.
Limey
May 30, 2015 04:39 PM
decencyxdefied
Mar 22, 2013 10:48 AM
Kojax
Jun 29, 2010 11:42 PM
relli
Nov 5, 2007 06:51 AM
plevine1
Aug 27, 2007 09:33 AM
