Lower Tree Pinch bolt
Old Mar 14, 2010 | 05:21 PM
Wonkaboy's Avatar
Wonkaboy
Default Lower Tree Pinch bolt
I'm installing my blinker relocation kit on the lower tree , What tool do i use for the pinch bolts ?
Thanks !
Old Mar 14, 2010 | 05:57 PM
bberck's Avatar
bberck
Its a T-45 Plus for the pinch bolts
A regular T-45 will usually work but its not the right size.
Old Mar 14, 2010 | 06:19 PM
Wonkaboy's Avatar
Wonkaboy
Would Sears have it ?
Thank's
Old Mar 14, 2010 | 06:26 PM
bberck's Avatar
bberck
Thank's
You can get them from sears but depending on your store they may need to be ordered.
Old Mar 14, 2010 | 06:32 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I got mine from Sears. But I would give the cernter of each bolt a smack with a small punch & hammer to loosen the thread locker (tip from Joe K) because I broke my first Craftsman T-45 on mine.
Old Mar 14, 2010 | 07:10 PM
Wonkaboy's Avatar
Wonkaboy
Thanks i will have to try that !
Old Mar 14, 2010 | 07:11 PM
Wonkaboy's Avatar
Wonkaboy
Ok , Thanks Wonka !
Old Mar 14, 2010 | 09:53 PM
rdondes's Avatar
rdondes
Also, if you put the T-45 bit on a hand held impact driver, the smack (on the impact driver) will also turn the pinch bolt loose-wise. As JRK et. al. have advised, use a heavy hammer (eg. hand sledge), not a light hammer that will bounce off of the impace driver. A hand held impact driver is also very helpful in removing other retarded Torx fasteners (such as those holding the derby cover on) until they can be replaced with sensible socket head bolts.
Old Mar 14, 2010 | 10:33 PM
Lonerider98's Avatar
Lonerider98
Stage IV
I have had to drill mine out. Suggest replacing them with socket head bolts also!
VazquezFXDP
Oct 25, 2018 01:53 PM
SLV
Mar 6, 2013 12:59 AM
Stickman53
Sep 8, 2010 12:19 PM
neocontra
Oct 6, 2009 04:16 PM
jbatp92
Dec 26, 2006 11:29 PM
