Check Engine Light
Old Aug 1, 2006 | 09:56 PM
phreak's Avatar
phreak
Default Check Engine Light
Turn the key, phlip it to run, check engine light comes on like it's supposed to. Wait phor it to go off. Then wait 5 more seconds, and it comes on again phor 8 seconds.
Not sure why it's coming on phor a second time. Bike starts and runs phine.
I tried pulling the main phuse to see if that would reset it, no dice.
Anybody got any ideas?
This on on an 06.
Old Aug 1, 2006 | 10:16 PM
gman's Avatar
gman
Default RE: Check Engine Light
Have you run the codes?
Old Aug 1, 2006 | 10:26 PM
phreak's Avatar
phreak
nope still trying to phind out how to retrieve them. I can't phind it in the service manual.
Old Aug 1, 2006 | 10:39 PM
gman's Avatar
gman
check out the efi/electrical forum, or go to search on this site. search for dyna codes. you will find how to get them and a table listing them all. you don't need any tools, since the codes are presented on the odometer.
Old Aug 1, 2006 | 10:47 PM
mud's Avatar
mud
ORIGINAL: phreak
This on on an 06.
Try this freaque (error codes):
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button.
Background lighting should illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate.
The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu
"PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module.
The module that is flashing is the one you are going to check.
To move from one letter (module) to the next, you push the odometer reset button one time.
(from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release.
If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s.
Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button.
Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and
holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch.
Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9.
If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
mudddd
Old Aug 1, 2006 | 10:52 PM
phreak's Avatar
phreak
thanks gman & mudddd.
gunna check it out after I eat.
Old Aug 1, 2006 | 11:25 PM
phreak's Avatar
phreak
I got it.
phound some info on checking the codes, phound I had a p0131, phront o2 sensor low(lean). Cleared the code, and it hasn't come back yet.
Old Oct 9, 2006 | 12:44 AM
mlbuckner's Avatar
mlbuckner
I tell you this forum is awesome, thank you for the DTC retrieval process. I recently had a check engine light come back on after it went of. Using this method I was able to determine a code of P1353. Does anyone know how to find out what the code means.
Thanks,
Matt
Old Oct 9, 2006 | 02:15 AM
WS6 Formula's Avatar
WS6 Formula
Trouble Code Link
Old Oct 9, 2006 | 08:39 AM
mikeurig's Avatar
mikeurig
Front cyclinder no combustion. Very close to the coil codes, make sure your plug wires are seated.
