Tank Sticker
Old Aug 2, 2006 | 03:14 PM
mikec's Avatar
mikec
Default Tank Sticker
I want to remove the HD sticker on the side of the gas tank.
I looked at some earlier post about this and I don't believe
anyone addressed the problem about there being clear coat
over the sticker. Can it still be removed without screwing
up the finish. If yes How?
mikec
Old Aug 2, 2006 | 04:10 PM
Sammi's Avatar
Sammi
Default RE: Tank Sticker
I'd be interested in knowing too.
I can't believe there is a way of removing the sticker without screwing up the clear coat, though.
Sammi
Old Aug 2, 2006 | 04:13 PM
stbobber's Avatar
stbobber
I used fishing line and some wd40 to remove the glue on the reflectors, but for the tank I just peeled them off, had to go to the store for some goo-gone. It was a lot of rubbing but it looks fine, no scrathes. Just be careful when peeling off, I cut my finger on one of the tank badges.
Old Aug 2, 2006 | 04:27 PM
mikec's Avatar
mikec
Look at Sammi's bike above......not a badge. It's a decal.
You noway no how will get fishing line behind that.
I guess.......new paint job.
Old Aug 2, 2006 | 04:38 PM
subculture08's Avatar
subculture08
I had the clear coated stickers on my 04 FXDI.
I sent the tank back to HD for re-painting. Cost like $250. (Vivid Black) Dealer took care of shipping.
Worth it I thought.
Old Aug 2, 2006 | 06:09 PM
but Ill try 2 try's Avatar
but Ill try 2 try
If you go to the trouble of repainting I hope you have a cool design picked out. I can't believe the prices of the custom tanks at different dealers.
Old Aug 2, 2006 | 06:25 PM
mikec's Avatar
mikec
NO $HIT! For what that cost, I might learn to paint myself.
How much can an Air Brush cost?
Old Aug 2, 2006 | 06:34 PM
AZ Rider's Avatar
AZ Rider
The decal that is clear coated over the paint?
How to remove? I'd say a good bit of sanding but then a new paint job would be in order.
Old Aug 2, 2006 | 06:53 PM
imboden's Avatar
imboden
can't get the sticker off without messin up the clearcoat. clearcoat is a layer of clear paint, so there's now way around that. you'll either have to strip the tank off the bike and sand it off....then either paint the clear again or send it in somewhere. good luck dude.
I suppose another option would be tryin to find a tank badge that covered up the decal....if you could find one that worked. but I'd just have it done...especially if you don't have any experience with paintin stuff. If you decide to sand it yourself, be sure and make an investment of some wet sandpaper, 400 through 2000....and be careful!
Old Aug 3, 2006 | 02:53 AM
mikec's Avatar
mikec
That's an idea worth looking into. Let you know if
I find something.
