Trans. Pulley Locking Tool.
Old Mar 26, 2010 | 07:43 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Default Trans. Pulley Locking Tool.
Ok, What did everyone use for holding the Trans pulley while wrenching on that 2 1/4" nut. I was able to use a small "C" clamp to get the 2 SHCS out. Do I need a bigger clamp? Will an impact wrench do the trick? Do I need to be thinking farther outside the box?
Old Mar 26, 2010 | 07:48 AM
redrubicon2004's Avatar
redrubicon2004
When Joe and I did his, we used a locking tool. He borrowed them from a HDF memeber.
Old Mar 26, 2010 | 09:15 AM
tdshepard's Avatar
tdshepard
Unsubscribed From Forum
I hung some weight on the rear brake pedal. Definitely use an impact, my sorry 1/2" air wrench could not do it. I rented a 3/4 electric and problem solved..........
Old Mar 26, 2010 | 09:54 AM
jaysonL's Avatar
jaysonL
I'd love to do this , but I'm a little dubious about tearing the primary open . Also , it seems to be a huge cost . The pulley , the socket , all the gaskets . What is the over all cost ?
Old Mar 26, 2010 | 10:18 AM
HOGRIDA_06's Avatar
HOGRIDA_06
I think I'm gonna build a tool similar to this.
http://www.harley-davidson.com/en_US...ts/-J04995.pdf
Jason...I'm at around $200 but I'm reusing the prim. cover gasket($30) and I already had sealing bolts in my tool box. But I did have to buy trans. seals. The main reason I'm doing this project is fixing a tras leak.
Old Mar 26, 2010 | 10:30 AM
SURFOR Chop's Avatar
SURFOR Chop
Sorry for the hijack, ... hope to remove my chain drive so I can install my BDL belt drive ... maybe tomorrow ....
Will start up a new thread with some photos if I get to it ....
R/
'Chop
p.s. those with '05 and earlier bikes contemplating this ... your socket is a different size (see Georges Garage tool page) ... I think it is 1-7/8" vice 2-1/4" ....
Last edited by SURFOR Chop; Mar 27, 2010 at 09:02 PM. Reason: Realized I don't need the socket ....
Old Mar 26, 2010 | 10:35 AM
tdshepard's Avatar
tdshepard
I was at around $210 for parts including a baker inner bearing, made my own socket like Hogrida did......
Old Mar 27, 2010 | 06:45 PM
HOGRIDA_06's Avatar
HOGRIDA_06
So I made a crappy locking tool, it works, but barely. My problem now is... that nut is stuck. I'm on it with a 4ft. breaker bar and can't get it to budge. I just hit it up with some PB Blaster and I'll try it again in the morning. I'm also gonna grab my old mans compressor and impact.
Old Mar 28, 2010 | 12:12 PM
HOGRIDA_06's Avatar
HOGRIDA_06
That sucker is STUCK! Can't get it with an impact. I was just bouncing on the end of a 4' breaker bar and the sucker won't budge. WTF?
Old Mar 28, 2010 | 12:57 PM
Taddeoeg's Avatar
Taddeoeg
Super loctite plus tons of pressure from running the bike. Try some heat to soften the loctite. Bouncing on a 4' bar is about par for the course.
You are talking about the compensator nut, right? Cause the clutch nut is left-hand threads (don't think that one's 2 1/4 IIRC tho).
