Screamin Eagle Stage 2 Kit
Old Mar 29, 2010 | 08:25 PM
601StreetBob's Avatar
601StreetBob
6th Gear
Default Screamin Eagle Stage 2 Kit
I have a 09 street bob with a stage 1 kit. If i go with a stage 2 kit what will kind of increase in performance will i see? Im also running vance and hines short shots. Will my bike get louder?
Old Mar 29, 2010 | 09:39 PM
sanlyn's Avatar
sanlyn
Are you adding the Short Shots as part of the Stage II upgrade? If so, you should have an increase in performance AND sound. I went from stock to Stage II with the Vance & Hines Pro Pipe ... here was my Dyno run:
Old Mar 29, 2010 | 11:12 PM
red devil's Avatar
red devil
You should be in the mid 80's hp & high 90's to low 100tq. I would recommend you get some head work done at the same time. It will only cost another $400 or so more and makes a world of difference! You would be in the 100/100 range no problem. But you might want to look into a good 2-1 pipe to get the maximum potential out of the build.
Old Mar 30, 2010 | 12:00 AM
gregbenner's Avatar
gregbenner
I have a 2007 with a stage 2 103. I am not into noise, so have stock exhausts. 85hp, 105 tque. Many of the aftermarket exhausts will actually reduce power. All depends on what you want.
shadogang
May 5, 2015 11:03 AM
Zeke800
Oct 25, 2014 03:23 PM
Dreamtab
Jul 17, 2014 09:00 AM
jmcdermit
Sep 15, 2013 09:59 PM
Swamphunter
Screamin Eagle CVO Models
Jul 19, 2009 09:24 PM
