Slip-on's Question
Old Apr 5, 2010 | 07:41 AM
JonV's Avatar
JonV
Default Slip-on's Question
If I throw a set of V&H Slipons on my FXD, no re-map is required right?
Old Apr 5, 2010 | 07:45 AM
dFREDb's Avatar
dFREDb
Right. Now get ready for a zillion other views on this subject
I know it's o.k. cause I did it myself. You'll need a remap if you change the intake side.
Old Apr 5, 2010 | 09:10 AM
ColdCase's Avatar
ColdCase
Late model bikes, no re-map, the ECU will self tune to it. I've also done this without issue except for mild decel pop. I used an XiED to reduce engine heat.
Add a free flow air filter on a well running bike, you won't have to re-map. You may find you want to because, although the ECU will self tune closed loop close enough, it may miss the open loop A/F targets enough to make a noticeable throttle response and WOT performance impact. Its not a safety/durability issue, however.
A factory download (re-map) will fix this back to the de-tuned factory settings. If you are going to spend that kind of money, think about investing in a fueler, tuner, or tuning kit instead.
Old Apr 5, 2010 | 09:19 AM
JonV's Avatar
JonV
It's an 09 FXD, that will recalibrate?
I was contemplating the whole ball of Wax, V&H Pipes, PC V, AC but just suffered a financial setback, **** happens...
I just don't want to get sold a bill of goods when I go to get the Slipon's..
Thanks,
JV
Old Apr 5, 2010 | 09:29 AM
ColdCase's Avatar
ColdCase
08 and newer bikes certainly, anything with a working O2 sensor probably. Throw a set of pipes on and go out and enjoy your ride without any anxiety. There may be a salesman try to tell you different, but thousands of riders throw slip-ons onto a well running bike without any issue short of attracting the constables and minor decel pop (not all bikes but most and it doesn't hurt anything). If she runs a little hot for you, get yourself a used set of XiEDs for about $50 and enjoy the ride even more.
Old Apr 5, 2010 | 06:57 PM
nitebobber08's Avatar
nitebobber08
when i put the rush slipons on the bike i rode it for a week or so before evry joe dick i knew told me i should get it remapped. i didn't really want to cause the total cost was like 400. i did it though. do you have the stage 2 on the bike already cause if you do it won't cost that much.
Old Apr 5, 2010 | 07:37 PM
bikecop40's Avatar
bikecop40
I did the same with my Rush w/2" baff. total a waste of $350.00. (the remap)I sold the Rush pipes on E-Bay, bought a set of Big City Thunder Baffles inserted them into the useless SE slip-ons the the dealer had the ***** to talk me into at the time of purchase.The end result a nice sounding BEEP RICH sound. sorry just venting.
Beetlejuice
May 7, 2013 09:03 PM
Dim100
Aug 7, 2011 04:13 PM
Bluegrasser
Exhaust System Topics
Mar 17, 2009 05:07 PM
deadbug
Dec 16, 2008 10:18 AM
Guitarman52
Aug 17, 2008 10:02 AM
