Where does this wire attach?
Old Apr 19, 2010 | 10:30 PM
kansaskid72's Avatar
kansaskid72
Account Retired
Default Where does this wire attach?
Under the lower triple tree, there is a screw that goes in and it has a wire connected to it with another screw on the end. ....I'm having a hard time finding where the other end goes...it's a smaller screw but I had the trees powdered and I think they may have covered the other hole? Can you look under your Street bob triple tree and let me know? It was a while since I took it apart and can't find it in the service manual anywhere I've looked. I've got a 2007 Street Bob.
Thanks!
Old Apr 19, 2010 | 10:37 PM
macnab_sf's Avatar
macnab_sf
To the handlebar riser bolt on mine ('06). Transfers ground from triple tree to handlebar.
Old Apr 19, 2010 | 10:44 PM
kansaskid72
Account Retired
Isn't that handlebar riser bolt on the upper tree?
Old Apr 19, 2010 | 10:46 PM
kansaskid72
Account Retired
Oh, there is a little screw hole on the top rider side of the upper tree...so the small screw goes in there, and the larger ring goes under the right riser bolt on the bottom of the upper tree?
So what goes in the bottom of the lower tree, in that protruding circle in the middle with the screw threads?
Old Apr 19, 2010 | 10:49 PM
macnab_sf's Avatar
macnab_sf
Yep - under the upper triple.
Do we have different risers? (06 vs 07)... My wire is very short, has a big loop on one end (riser bolt passes through) and small loop on other end (screws into upper triple).
macnab_sf's Avatar
macnab_sf
That's a clip that holds my front brake line steady as it passes through the area.
Old Apr 19, 2010 | 10:50 PM
kansaskid72
Account Retired
Yea, wondering if I really need it...looks like crap now that I powdered the trees black.
Old Apr 19, 2010 | 10:51 PM
kansaskid72
Account Retired
You think I need that Grounding wire for anything?
The other screw hole I don't need anymore...got ride of the stock front brake line
Old Apr 19, 2010 | 10:57 PM
macnab_sf's Avatar
macnab_sf
I can't tell you if you need the grounding wire or not. On mine I am running solid metal bushings, so the bar and the triple and risers are all electrically connected.
Old Apr 19, 2010 | 11:11 PM
kansaskid72
Account Retired
Anyone else? Do I need that grounding wire connecting the upper tree to the handlebar riser bolt?
Hogpro
2014-2024 Touring Models
Nov 14, 2014 09:58 AM
blueangel73
Jan 12, 2011 01:34 PM
cryan9
Jun 8, 2010 02:29 AM
Dynamite17
Mar 23, 2008 10:11 AM
Chipstah
Jul 12, 2007 09:21 PM
