Front Tire has a screw in it.....
Old Apr 25, 2010 | 11:22 PM
"Dutch"'s Avatar
"Dutch"
Default Front Tire has a screw in it.....
As the title states; I went out today, went for a ride, met up with my family..blah...blah..blah...screw stuck in the middle of the tire. Went to Auto Zone and purchased a cigarette lighter tire pump. Filled and rode the bike the three or less miles home.
The tire has 2700 miles on it. I understand that I have a tube inside the rim ('09 Street Bob with spokes). So plug it? I will purchase a new tube. So I feel plugging it is safe since the tube is holding most of the pressure. Am I wrong on this? I would like all opinions.....even the smart *** ones.
Old Apr 25, 2010 | 11:28 PM
brandonsuperglide's Avatar
brandonsuperglide
If its a small screw just pull it out and replace the tube, no plug. If its a large screw use a tire patch and replace the tube. If it looks to bad replace the tire, its the only thing between you and the road.
Old Apr 25, 2010 | 11:45 PM
"Dutch"'s Avatar
"Dutch"
Sorry forgot the size of the screw in the tire. It is about 5/16 in size, and is inside the tread pattern.
Brandon, thanks for the response. I am looking at the process you stated; new tube (give at this point), determine if the hole is deemed manageable for a plug or just replace.
So would a 5/16 screw hole be deemed a manageable hole to plug?
Old Apr 25, 2010 | 11:59 PM
brandonsuperglide
Dont use a plug on a tube type tire use a tire patch. Cant say if I would repair or replace without seeing it. Im a little over cautious when it comes to my tires.
Old Apr 26, 2010 | 12:28 AM
W G Junkie's Avatar
W G Junkie
Don't cut corners when talking bout tires. Only use patches. Plugs we're the way to go in a pinch, but there's a reason they patch and not plug anymore. Patches simply hold better. Definitely get a new tube as you said. Keep good rubber down!
Old Apr 26, 2010 | 02:58 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Yeah; patch and tube...should be good.
Old Apr 26, 2010 | 05:58 AM
OldMike's Avatar
OldMike
Might have to re balance too.
Old Apr 26, 2010 | 08:40 AM
"Dutch"'s Avatar
"Dutch"
Thanks for the responses everyone. Patch I will. Tube is a given. Again Thanks.
Old Apr 26, 2010 | 09:16 AM
Blargh's Avatar
Blargh
take the tire off the rim first and inspect - make sure none of the steel is poking in (especially since it was a screw and not a nail)
not to completely threadjack...but on a similar note - I just took delivery yesterday on a used (new to me) 09 street bob (1900 miles)...I bought it sight unseen and as it was coming off the truck I noticed the tires looked low. Turns out the front had about 6psi and the rear was about 16psi.... I pumped them both up (f/32, r/36) ...
my question is - could rolling around like that for probably a few months have damaged the tubes? I know the dealer (not a M/C dealer) wasn't driving it much, but no telling if they put 5 or 10+ miles on low pressure tires?
I wonder if it'd be safer to just have both tubes replaced in case they were so low they were shifting inside the tires and causing wear? Even though I like the look of spoked rims, I may switch to mags just so I have the option of plugs in the event of a flat out on the road.
Old Apr 26, 2010 | 10:25 AM
SC-Longhair's Avatar
SC-Longhair
Personally, I'd replace both.
Our lives depend on only two tires being up to snuff. The tire is now breached and could become a real problem in the future.
This is just me. You can certainly take your life in your own hands.
