Leak from front caliper
Old Apr 29, 2010 | 02:07 PM
Droop's Avatar
Droop
Default Leak from front caliper
While changing the front brake pads I was removing the top bolt that holds the front caliper to the fork on my 05 FXDI when brake fluid began to gush out the the caliper the more I loosened the bolt. I've retightened the bolt for now to stop/slow the leak. I had changed out the front tire last week and thought I was careful to not cross thread the bolts and pins while reinstalling the caliper. What is the likely problem and what do I need to do? Also what was I likely to have done to cause this?
Thanks
Old Apr 29, 2010 | 02:36 PM
rounder's Avatar
rounder
you loosened the wrong bolt.
Old Apr 29, 2010 | 03:01 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
+ 1 if it was item # 8 you loosened.....
My advice would be: check this thread Official Dyna service part# thread for the '05 models Service Manual's p/n and try to find them at Ebay.
Do not forget to check the level of the brake fluid in the front brake master cylinder.....
Old Apr 30, 2010 | 05:57 AM
8541hog's Avatar
8541hog
Looking at the diagram above, which bolt did you loosen that caused the leak?
BTW, You do not need to remove the caliper to remove a wheel, and you do not need to remove the brake line to remove the caliper, or to change the pads.
SmittyFXDL
Feb 18, 2019 05:15 PM
CBCanada
Jun 4, 2016 06:05 AM
windrider24
Apr 18, 2012 11:35 PM
lewain
Jun 8, 2011 09:25 AM
mattVA
Jun 14, 2010 12:54 PM
