Running Hot... Go Synthetic?
Old May 5, 2010 | 06:32 AM
The Reaper's Avatar
The Reaper
Default Running Hot... Go Synthetic?
I am due for my 1k service and I have heard running synthetic will help with the temp? ( I have just over 1k on her, appointment is 10 days out should i stay off her?)
Also now that I have you guys here! Is lugging the motor on a twin cam a bad thing? I was told it will cause the cam to twist apart.
Old May 5, 2010 | 06:44 AM
8541hog's Avatar
8541hog
Where to start...lol
Syn will not necessarily make your motor run cooler, but it does stand up better to a hot motor than dino oil.
Don't worry about the 10 days, unless you are planning to ride more than 500 miles during that time, a couple hundred miles won't hurt you.
Lugging is not a good practice, but twisting the cams apart, that's a new one that I have never heard, nor can even theoretically imagine being possible. Lugging means low torque, it would take a lot of torque to twist a cam apart.
Hope this helps.
Old May 5, 2010 | 06:54 AM
rounder's Avatar
rounder
first, don't lug your motor. Synthetic does lower the operating temp from what I have read. Seems to be about 10-20 deg. or so. Synthetic has the advantage over dino juice in that it breaks down less as the temperature rises. So run synthetic.
Old May 5, 2010 | 07:01 AM
nvsteve's Avatar
nvsteve
There is a model year or two where there were some issues with cams but it wasn't from lugging. Stll, lugging is not good for the motor.
As said earlier lower oil temps may or may not result from using synthetic oil, but, it does stand up much better to high operating temps.
Old May 5, 2010 | 07:09 AM
08fxdf43202's Avatar
08fxdf43202
I've been using full synthetic in mine since it was new 28,500 miles ago; crankcase, primary & trans. I also do my own service.
YES lugging the motor is a bad thing! With the full synthetic fluids running higher RPM's, for longer periods of time is not a problem.
Old May 5, 2010 | 07:15 AM
Dale_K's Avatar
Dale_K
What makes you think the bike is running too hot?
Old May 5, 2010 | 07:20 AM
maddghost's Avatar
maddghost
If you lug for a second or 2 nothing's going to happen,but I can't see why anyone would want to do that,just downshift. Syn oil won't cool your engine extra fuel will do that! There's ways of adding fuel, the cheap easy way is with nightrider's Xied's, other ways are more expensive fuel injection modules such as a powercommanderV, or try not to run so much in heavy traffic. Last if you want to keep ridin the *** off a her just get a filter and 2.5 quarts of oil and do the engine oil change 'tis mornin'
Old May 5, 2010 | 07:22 AM
8541hog's Avatar
8541hog
While lugging the motor is not a good practice, it will NOT hurt a 4 stroke motor. It will cause issues for a 2 stroke which are designed to run at high RPM's. You don't want to continually cruise below 2000 RPM, but occasional low RPM's will not damage anything.
Old May 5, 2010 | 10:19 AM
1320go's Avatar
1320go
Smile wrong
8541 You are wrong to tell someone that knows even less than you do that lugging his motor wont hurt it .As for the 2 stroke statement thats bull **** too.
Old May 5, 2010 | 10:25 AM
lionsm13's Avatar
lionsm13
What kind of bike, what size of motor, and what are you doing for your air/fuel managment? This would be where you would start for cooling.
A Power Commander would be a no brainer/plug and play unit that works for many, (myself included) and then a stage 1 air cleaner, a free flowing exhaust and then you would start to get some cooling.
