Swapping out PCV for TTS
Old May 14, 2010 | 10:28 AM
SURFOR Chop's Avatar
SURFOR Chop
That's the thing about the TTS and T-Max (not sure what others) ... they're total engine control modules that can reset the speedo to work right if you change a sprocket or wheel size for example ...
Also, they are programmed to adjust timing--a huge big deal for fine tuning the motor's performance ... (seems to me it would obviate the necessity of a 4 degree gear, that some have added) ... both front and rear AFRs can be adjusted separately ... ad nauseum ....
A lot of good stuff ....
R/
'Chop
Old May 14, 2010 | 10:39 AM
Bikepusher's Avatar
Bikepusher
Originally Posted by SURFOR Chop
Not bad ... with 110 cube's it should be capable of much more, but you're still crankin' out more hp and tq than probably 80-90% of HDs on the road ....
Key is if you're happy with the result ....
I really like the improvement to the looks of your Fat Bot the wheels and pipe contribute (IMO) ... a very nice lookin' bike ... and now you've upped the performance commensurately ... sweet ....
R/
'Chop
p.s. there's a thread 'post your dyno sheet' or something to that effect ... if you have a scanner or photo of it, you should post it there ....
Thanks Chop,
When I left I spaced didnt get my print out, I will get it soon. I have to ride it a little more but I would have to say its a better running bike not more HP.
Old May 14, 2010 | 11:33 AM
markrumsfield's Avatar
markrumsfield
Hey bikepusher whats your thoughts on Cycle Doctor, good,bad so so, would you go back there again?
Old May 14, 2010 | 07:31 PM
Bikepusher's Avatar
Bikepusher
Yes, I would recommend them, they seem to really know there stuff, clean organized shop, no clunkers laying around and friendly. I'm not disapointed in my results and the bike runs perfect, just thought TTS with the tuning would get me a little more power than with the PCV did.
Old May 14, 2010 | 09:01 PM
markrumsfield
Yeah I hear ya. I been running my bike with just the factory download for about 3 years now and seriously thinking about getting TTS, not sure how much Ill get out of it either. Im not too far from Cycle Doctor so if their good with TTS I might give em a try...
Old May 14, 2010 | 10:09 PM
SC-Longhair's Avatar
SC-Longhair
I think the beauty of the TTS/Tmax management systems is that you, the rider, can tune your bike. You save the money of having to go to a tuner.
Comparing the stage 1 download to the TTS is like apples and oranges, Bikepusher. The stage 1 download is just as much a canned map than one you would download from the powercommander website. The TTS/Tmax would create a map for your bike.
I'm slowly beginning to understand those tuners and can say that when the time /money available to me I will probably purchase one or the other.
I currenyl have the pcIII running a canned map from the pc website. Bike runs ok but understanding I can do any mod and then go for a ride and self-tune it is becoming more appealing to me as the days go on.
kylebryan
Jan 12, 2015 04:57 PM
pittz5
May 14, 2011 01:17 PM
Clint55
Oct 24, 2010 03:02 AM
ga4boats
Aug 5, 2010 03:29 PM
rm4040
Oct 26, 2009 10:23 PM
