Clutch lever response
Old May 19, 2010 | 10:45 AM
bigmikaele's Avatar
bigmikaele
You are right, it was real late and I couldn't think of the name of that dang thing thanks for correcting me.
Mike
Old Jun 20, 2010 | 01:27 PM
FXD-raw's Avatar
FXD-raw
I did a few things to attempt a remedy for this problem, finally. I did a clutch adjustment and backed out the two nuts that attach the forward control extender bar (connection between the shifter in primary and foot lever itself) because they seemed to be a bit tight.
None of these things worked.
I dropped by the "stealer" and asked a tech what he thought and he mentioned that he's seen the problem before. GREAT!!
So he said that the foot shift lever on the forward control is too tight where it is seated between the peg and the mount. It's difficult to explain but I'm going to check this out and come back with results.
Old Jun 20, 2010 | 01:51 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by FXD-raw
...I noticed that when I would down shift, the lever did not automatically return to downshift through the gears.
Have had the same "sticking" issue on my FXDP heel/toe shifter lever a few years ago.
I disassembled the heel/toe shifter (item 25), took out the shifter lever (item 24), cleaned it, put in some grease into the shifter shaft housing (item 26) and problems were gone!
Old Jun 21, 2010 | 05:34 PM
FXD-raw's Avatar
FXD-raw
That is exactly what I did. I sanded the shaft and cylinder that connects the foot shift lever to the shift arm. Upon my first test ride, it seemed to work fine. Thanks for the input- the sticking was driving me nuts.
Machine213
Apr 4, 2016 09:53 AM
dirttoo
EVO
Apr 11, 2015 01:05 PM
FX4 Level II
Feb 4, 2009 08:19 PM
notbob
Oct 11, 2007 03:52 AM
Rob2002
Jul 29, 2007 11:23 PM
