problem starting/idling when wet
Old May 23, 2010 | 08:45 PM
NoLongerAmember's Avatar
NoLongerAmember
Originally Posted by CRZYLGZZ
CB, sorry i wasnt explaining my self propers,, i use the wd-40 to remove the moisture, as well as corrosion, i use a toothbrush, then wipe it all down,, then i use the grease, and reconnect. I do this before the winter, after the winter, end of spring , and as the fall approaches.
Old Navy habits. im scarred with the blasted 3M maintenance intervals on those ridiculous PM cards they used to make us carry around.
I wonder if they still do those cards.
No apology needed, I figured that what you did and just wanted to point it out.
CB
Old May 23, 2010 | 09:19 PM
NoLongerAmember
Originally Posted by CRF
with the dielectric grease - do you put it right on the connectors? don't they need to mate directly? I read that the grease just goes around the seals rather than on the connectors directly..... true or false anyone?
The dielectric grease is not conductive and does not absorb moisture. You need to make sure the male and female terminals are clean and fit tight. The grease gets displaced when the terminals are connected and then forms a seal around the connection, if there is a problem with the grease interrupting the connection then you have a loose connection problem, not a grease problem. I squeeze a little in each receptacle and coat the male surface because moisture can come in from the back side, even more so when washing your bike.
When I took my fuses out I was amazed at the white powdery corrosion that had built up and I don't usually ride in the rain if I can help it and I am pretty careful when I wash it. If you remove the fuses/relays and they have corrosion I would replace the fuses and clean the relay($$$) connections. I use a new fuse and run it in and out of the female connectors several times to clean them, unless you remove each one separately from the fuse block and clean them, even a brush can't really get down into the connector.
The reason I like CRZYLEGZZs WD-40 idea is that the electrical cleaners out there can damage your Powder coating and the WD-40 will not, but I would still cover the area though. Loctite makes a cleaner and if your female connections are really corroded you may need to use a heavy duty cleaner, just make sure you cover everything!
https://tds.us.henkel.com//NA/UT/HNAUTTDS.nsf/web/E7D49FEC1C1903B6882571870000D946/$File/DIEG-EN.pdf
CB
Old May 25, 2010 | 11:23 PM
stormcooker's Avatar
stormcooker
Has this problem been resolved yet???
I rode it to the dealership today to get fixed. Scariest ride in my life, It ran like the tank was half full of water. About 100 yards from the dealership it quit on me entirely and I coasted in....thankfully downhill. Dealership acted like it's never happened before or they never heard of such a thing. I told them I thought it was unsafe to ride and wanted it towed in but they refused and I rode it in one hour anyway. Makes me wonder.
Old May 25, 2010 | 11:30 PM
CRF's Avatar
CRF
they always act like its never happened before........ I think they teach them that in dealership a**hole school. You could go in there and ask for an oil change and they'd be like........hmmm; never heard of that before - hey! joe! - you ever heard of having to "change the oil"????
I think they do it just to fugg with you
Old May 25, 2010 | 11:47 PM
stormcooker
did I mention the bike has 400 miles on it too? worst break-in ever.
Old May 26, 2010 | 06:56 AM
CRZYLGZZ's Avatar
CRZYLGZZ
I'm at a loss. If it isn't water, then its something entrely wrong with the Bikes electronics.
But!! I'm almost certain that your connections and contacts are just fould with water and just need a cleaning.
I hope it all works out. Keep us Posted
Old May 26, 2010 | 07:41 AM
stormcooker
I wish there was a "no electronics" option and carb version. I never had a lick of problems with my 00' and 01' sportys
Old May 26, 2010 | 10:43 AM
stormcooker
Dealership called and said "your bike is getting a new crank position sensor..it will be here in 5 to 6 days".
So now I'm going to have cancel my ride to Americade in Lake George NY, and worry about what other parts are going to fail with fewer than 500 miles on them.
Old May 26, 2010 | 10:48 AM
CRZYLGZZ's Avatar
CRZYLGZZ
i wouldnt sweat Americade, you got 2 good solid weeks, call the dealership and voice your concerns and
Let them know the Amount of money you already spent planning this trip that may not happen.. due to a defect on parts.. Please have them expedite this.
5-6 days on a sensor seems abit much..
Old May 26, 2010 | 11:55 AM
NoLongerAmember
Was there a DTC stored and the check engine light on? I did not see where you mentioned that. Tell them to take the sensor off a bike on the floor! Check the sensor connector for corrosion, low miles does not mean there can't be corrosion.
CB
